  #41 (permalink)
Old February 6, 2013, 09:24 PM
ipaine's Avatar
So here are my newest scores. The difference is with these ones I OC'd my 580s.
GPU 801MHz / Memory 1025MHz / Shader 1602MHz
Old scores:
Icestorm: 178043
Cloudgate: 26947
Firestrike: 6837
New scores:
Icestorm: 180336
Cloudgate: 27064
Firestrike: 6967
NVIDIA GeForce GTX 580 video card benchmark result - Intel Core i7-2600K Processor,ASUSTeK Computer INC. P8P67 DELUXE
"Nothing sucks more than that moment during an argument when you realize you're wrong."
  #42 (permalink)
Old February 7, 2013, 04:51 AM
Originally Posted by r0k0 View Post
how come your getting better score on fire strike with 1 6870 when i have a 6990 ????
Ha. Awesome.
No idea really. I thought it did rather poorly to be honest. FPS in that test was slow as cold molasses.
I do have my 6870 overclocked from a 900 clock to 980 but I doubt thats it.
  #43 (permalink)
Old February 7, 2013, 02:57 PM
r0k0's Avatar
which drivers are you using ?
Main Rig
Intel Core i5 2500K - 5.0
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
AMD Radeon HD 6990 4GB 880 / 1300
Crosair 600T White / Enermax Revolution 920W
A-DATA 120GB SATA3 SSD / Seagates 1TB Spare SATA3
Canadian Eh ?
  #44 (permalink)
Old February 7, 2013, 03:20 PM
JD JD is offline
Originally Posted by Caldezar View Post
There appears to be some very odd results, particularly when comparing results for 'Fire Strike'. I'm not sure why some people's results are so much higher/lower than others. Originally I thought it may be due to nVidia vs AMD, but that doesn't seem to be the case.
Firestrike is designed for "high-end multi-GPU systems", so I think if you have SLI/Crossfire, you'll achieve higher results.
Firestrike Extreme is a true benchmark IMO, but you need to buy 3DMark Advanced to be able to run it. It's the only thing that consistently runs <30FPS on my system.
  #45 (permalink)
Old February 8, 2013, 01:24 AM
you don't need to buy it to run it. I ran it on the free version.
  #46 (permalink)
Old February 9, 2013, 11:18 AM
great_big_abyss's Avatar
Rig in My Specs
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
  #47 (permalink)
Old February 10, 2013, 10:14 AM
ern88's Avatar
My results Not too bad with my Sapphire HD7950 Vapor-X
162623 Ice Storm 10/02/13 18:08:19
1Intel Core i5-2500K ProcessorDetails Delete
AMD Radeon HD 7950Add to compare
17619 Cloud Gate 10/02/13 18:08:19
2Intel Core i5-2500K ProcessorDetails Delete
6042 Fire Strike 10/02/13 18:08:19
3Intel Core i5-2500K ProcessorDetails Delete
  #48 (permalink)
Old February 14, 2013, 09:19 AM
Phill's Avatar
Here is my GTX 680 run with 310.90 drivers:
  #49 (permalink)
Old February 16, 2013, 08:27 PM
BlueByte's Avatar
Finally got a few minutes to install this beast.
AMD Radeon HD 7970 video card benchmark result - AMD FX-8350,ASUSTeK COMPUTER INC. SABERTOOTH 990FX
Didn't try to push it yet, might try to break 10K some day when I have some time.
  #50 (permalink)
Old February 17, 2013, 07:09 AM
Phill's Avatar
Wow what a Gpu score... D-E-S-T-R-O-Y-E-D my 680
3DMark 11 is online! Post you scores! Delavan Overclocking, Tweaking and Benchmarking 149 Yesterday 10:40 PM
pes 2013 vs fifa soccer 2013 yehia7000 Gaming 0 October 6, 2012 06:48 AM
3DMark 06 & Vantage scores Jonwall Overclocking, Tweaking and Benchmarking 164 June 19, 2012 07:12 AM
Team Fortress 2 Scores!!! Airshehan Gaming 9 August 4, 2009 09:26 AM
Curious about Vantage scores kragnorok Overclocking, Tweaking and Benchmarking 10 May 17, 2009 11:59 AM
