  #21 (permalink)
Old February 6, 2013, 05:54 AM
JD JD is offline
Originally Posted by Rollergold View Post
@Soull, Ya don't remind me. Why it works fine with a 690 but not with 2 680's is beyond me
@ JD, that link in your post is broken by the way
I'm really glad NVIDIA fixed things up after the whole 9800GX2 fiasco. Glad I bought a GTX690, though it looks like the "GTX780" is going to wipe the floor, but we'll see if it's worth upgrading or not. Going to be hard to let go of a $1k GPU
And I fixed that link, I had copied from the 1st post but it was a truncated link.
  #22 (permalink)
Old February 6, 2013, 12:46 PM
ipaine's Avatar
I will have to do a run of this tonight. But then again, it is going to make me want to upgrade my 580 sli. I don't need to but I will still want to after looking at the scores.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
  #23 (permalink)
Old February 6, 2013, 02:24 PM
"Quote This..."
My Results:
NVIDIA GeForce GTX 590 video card benchmark result - Intel Core i7-2600K Processor,ASRock Z68 Extreme3 Gen3
Don't forget to turn off vsync, aa, ambient occlusion and any other tweaks you may have enabled in the graphics cards control panel.
Also, both my cores were 99% during the tests so SLI is working. But the physics tests were definitely CPU only.
Black belt in CAPS LOCK.
  #24 (permalink)
Old February 6, 2013, 02:47 PM
r0k0's Avatar
AMD Radeon HD 6990 video card benchmark result - Intel Core i5-2500K Processor,ASUSTeK Computer INC. MAXIMUS IV GENE-Z/GEN3?
meh.. :(
Main Rig
Intel Core i5 2500K - 5.0
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
AMD Radeon HD 6990 4GB 880 / 1300
Crosair 600T White / Enermax Revolution 920W
A-DATA 120GB SATA3 SSD / Seagates 1TB Spare SATA3
Canadian Eh ?
  #25 (permalink)
Old February 6, 2013, 03:10 PM
Rollergold's Avatar
At least you beat me and my SLIed 680's
Asus P6X58-E WS | i7 920 D0 @ 4.01ghz W/ Apogee HD Block | 24gb (3x 8gb) Corsair Vengeance 1600 | 2x EVGA GTX 680 SC's in SLI W/ XSPC Razor Blocks |
4x 1tb WD Black Drives | SB Recon 3D PCIe | Swiftech MP655-SE Pump | Swiftech Maelstrom Res | CM HAF 932 | Corsair HX 850 (3 yr's old) | Asus VH236H + PA238QR
  #26 (permalink)
Old February 6, 2013, 03:16 PM
Black_Ice-Dragon's Avatar
Mine:
AMD Radeon HD 7970 video card benchmark result - Intel Core i7-3770K Processor,Gigabyte Technology Co., Ltd. Z77X-UP7
  #27 (permalink)
Old February 6, 2013, 03:32 PM
Shadowmeph's Avatar
I take it that a few tests like icestorm are not available in the basic install?
I cannot even get this to run on my Intel system and as for my AMD system well it is embarrassing to say the least hehe
Result not found
ok finally
Result not found
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
  #28 (permalink)
Old February 6, 2013, 03:37 PM
Caldezar's Avatar
According to 3DMark, you're 2500k is underclocked to 1.5GHz and still has the highest posted score... interesting.
  #29 (permalink)
Old February 6, 2013, 03:51 PM
Shadowmeph's Avatar
I was just noticing that myself on my Intel system
Folder :
  #30 (permalink)
Old February 6, 2013, 04:15 PM
Caldezar's Avatar
NVIDIA GeForce GTX 670 video card benchmark result - Intel Core i7-2600K Processor,Gigabyte Technology Co., Ltd. Z68X-UD3H-B3
There appears to be some very odd results, particularly when comparing results for 'Fire Strike'. I'm not sure why some people's results are so much higher/lower than others. Originally I thought it may be due to nVidia vs AMD, but that doesn't seem to be the case.
3DMark 11 is online! Post you scores! Delavan Overclocking, Tweaking and Benchmarking 148 Today 08:53 PM
pes 2013 vs fifa soccer 2013 yehia7000 Gaming 0 October 6, 2012 06:48 AM
3DMark 06 & Vantage scores Jonwall Overclocking, Tweaking and Benchmarking 164 June 19, 2012 07:12 AM
Team Fortress 2 Scores!!! Airshehan Gaming 9 August 4, 2009 09:26 AM
Curious about Vantage scores kragnorok Overclocking, Tweaking and Benchmarking 10 May 17, 2009 11:59 AM
