  #111 (permalink)
Old August 30, 2013, 09:20 AM
rjbarker's Avatar
^^^^ Are you guys talking about the additional 6 Pin PCI-E Power plug adjacent to the EZ Plug on the RIVE Mobo? If so, I certainly would use it if your going with 2 or 3 GPu's in your RIVE, I'm presently using mine and yes, a Molex to 6 Pin PCI-E adapter is fine as the power draw through this is not the same as plugging directly into the GPU.
I would never recommend using the adapter for a GPU, but for the PCI-E power plug on the Mobo the adapter is fine.
For 2 GPU's you're right, the additional PCI-E power plug is not mandatory, but should be used to ensure clean n ample power to PCI-E.
With my 3 GTX 680's requiring all 6 PCI-E power plugs from AX1200 PSU, obviously I have no more PCI-E power connectors to plug one more into the RIVE, so I used one dedicated Molex from my PSU to a PCI-E adapter (came in one of my GPU boxes).
Not sure what the "tech" is talking about, this set up is fine, maybe he thinks youre planning on using the adapter to plug into your GPU, which isn't recomended, particularly for high power draw high end GPU's.
Firestrike Extreme: 21.452
MARK 11: 32.530
  #112 (permalink)
Old August 30, 2013, 09:34 AM
fishingfanatic's Avatar
Smile Oveclocking Tweaking and Benchmarking
Yeah, with 3 titans I figured it would be wise to use all 3.
After that I likely won't need it but will probably leave them hooked up, so I can find them,....
Well that's going to have to wait a little longer, just went to try some cables and couldn't even do that, damn back!!!
I think I waste more time when doing things waiting for my back to give me a break.
Percs help 1 way but make things worse another. After 3 days of no throne activity I start to feel just like I'm more full of S^&t than usual.
Wife concurs...Gee thanks hon.
FF
  #113 (permalink)
Old August 30, 2013, 12:06 PM
Dzzope's Avatar
4/8 split???? Noooo go Motherboard connectors straight, don't go molex for the standard motherboard connectors...
If there is a 6 pin it is PCI-E, you don't *need* it so either skip or do molex to pci-e.. Otherwise forget it..
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
  #114 (permalink)
Old September 5, 2013, 09:52 PM
stoanee's Avatar
Workin my way up.
heatware
  #117 (permalink)
Old September 13, 2013, 10:57 PM
rjbarker's Avatar
^^^ Great Scores...considering $3.2K worth of GPU's :) Now...beef that score up further by OC'ing that 3960X to levels that its capable of ;) Just got my 3930K stable at 4.9 Ghz...!!!
MARK 11: 32.530
  #118 (permalink)
Old September 14, 2013, 09:44 AM
Yeah, I sure wouldn't mind finding that sweet spot. Don't know much yet. Looking at adjusting voltages but have to do more reading.
Other than disabling a few functions in the bios and adjusting the bclk and multiplier I haven't done anything else.
FF
  #119 (permalink)
Old September 14, 2013, 09:56 AM
rjbarker's Avatar
^^^ IV been able to reach both 4.8 and 4.9 by simply changing the mult and adding vCore, set LL Calibration to Medium.
I am using offset mode to keep the chip down clocked when I'm not gaming etc.
MARK 11: 32.530
  #120 (permalink)
Old September 14, 2013, 01:25 PM
Still not getting anywhere yet. Back to he books and the ROG site next I guess.
Thanks for the heads up RJ on those bios adjustments. Still struggling with that so I'll be writing stuff down to keep it fresh.
Simply too many new things at once to try them all and keep track... Must be the Steve Tyler years coming back to haunt me...
You know, too many women too many drugs and too much booze. Wish the too many women part was true...
Sure is hard to type when the dog keeps shoving her toy in your hands. Do you think she wants to play?
FF
3DMark 11 is online! Post you scores! Delavan Overclocking, Tweaking and Benchmarking 283 November 7, 2017 03:12 PM
3DMark 06 & Vantage scores Jonwall Overclocking, Tweaking and Benchmarking 206 March 25, 2015 10:19 PM
pes 2013 vs fifa soccer 2013 yehia7000 Gaming 0 October 6, 2012 06:48 AM
Team Fortress 2 Scores!!! Airshehan Gaming 9 August 4, 2009 09:26 AM
Curious about Vantage scores kragnorok Overclocking, Tweaking and Benchmarking 10 May 17, 2009 11:59 AM
