Old February 2, 2013, 10:15 AM
Shadowmeph's Avatar
Default why is my 4Ghz OC showing 1600mhz ?
I used the auto oc on my asrock z77 motherboard yesterday and when I booted into my system the 4Ghz showed . today I just booted into my system and it is showing 1600mhz , I am fairly new to OC on intels but is that some type of throttling or something? how do I turn that off
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old February 2, 2013, 10:17 AM
its intels speedstepping sstuff...
Basicallyt, it undervolts your cpu, and decreases the frequency to save power, but wel you stress test it or have a cpu load, it bumps it up to your prescribed voltage and clock frequency.
Try p95 and see if it stays at 1600mhz :)
Edit: I think if you diabsle intel speed stepping and c1e-c6 it should turn it off.
Bought Items:
GTX 470 from ZeroFlux
Swiftech MCW60 from chubaka
Sold Items:
Steelseries Siberia V2 to MAK
Zalman Fan Controller, OCZ Mem Fan Funguseater
Current system:
i5 2500k @ 5 Ghz
Zotac gtx 470
8GB Corsair Dominator ram @ 1333
Old February 2, 2013, 10:48 AM
Perineum's Avatar
Do not disable it When you need to it'll overclock again. It's working as designed.
Old February 2, 2013, 10:53 AM
Shadowmeph's Avatar
ok thanks for the info
Folder :
1600mhz with 200mhz? simer1 RAM 4 April 29, 2011 09:08 PM
[WTB] G.Skill ECO 1600mhz 2x2gb ram feerof Buy/Sell & Trade 20 December 29, 2010 07:04 PM
G.Skill NQ 1600Mhz OC help! Jelah Overclocking, Tweaking and Benchmarking 2 August 28, 2010 02:02 AM
OCZ Platinum 1600mhz 7-7-7-24 Vs Patriot Viper 1600mhz 8-8-8-24 Rocco_360 RAM 4 April 10, 2009 04:02 PM
OCZ DDR3 1600MHz 6GB Vs Patriot DDR3 1600MHZ 6GB appplejack RAM 1 December 9, 2008 07:08 PM
