-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   Max SAFE Voltage and Temps for 3570K? (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/59427-max-safe-voltage-temps-3570k.html)
great_big_abyss January 31, 2013 06:17 AM
What are the max safe voltages and temps for a 3570K?
Coach January 31, 2013 12:12 PM
I own two 3770k, I run one with 1.28v at 4.8Ghz. Raising vcore to try for a higher clock is pointless on this chip because no matter what I find instability even if temps are acceptable. The other 3770k will do 4.6Ghz with 1.3v. Same story as the first chip if I try to go higher. Temps are mid 70C for the chip at 4.8 and low to mid 80C for the other chip at 4.6.
Personally I would have no issues with temps <90C and that temps will most likey determine your max vcore.
Feanor January 31, 2013 01:45 PM
Totally agree.
You will hit the max safe temp way before you hit the vcore ceiling. Keep it under 80-85 when stressing, that being my own personal max (yours may be higher/lower,).
CroSsFiRe2009 February 1, 2013 11:57 PM
CPU-Z Validator 3.1
:ph34r:
jibz February 2, 2013 12:08 AM
I've benched my 2600k at 1.56v 5.2gh fully stable.
The only way to find the max safe voltage is to go over it.
Trocko February 6, 2013 07:27 AM
Yeah... if you are reall yworried, buy the tuner warranty from intel. Burn one chip out, then never go that high with the new chip :P
Dzzope February 6, 2013 07:44 AM
Problem with that is already shown above.. 1 chip will do 4.8 @ 1.28? and the other was 4.6@ 1.3
Just keep notching it up m8 and find your own limits.
great_big_abyss February 6, 2013 07:57 AM
I put it to 4.7Ghz, 1.35v. It's a little on the conservative side, I suppose, but since I fold with it, I didn't want to heat it too much. It's stable at about 70C currently.
Dzzope February 6, 2013 08:06 AM
I'd bump till I see instability and then back it off a couple of notches for 24/7 use (without going too hot, bout 80 for my liking)
But then 4.7 may be enough, depends on your own preference.
great_big_abyss February 6, 2013 08:09 AM
I may yet fiddle with it. If I can get higher without going too much hotter, then I'll be happy. I know that right now, with that voltage, it's just on the stable side of unstable.
