  #41 (permalink)
Old February 2, 2013, 04:04 PM
Originally Posted by Soullessone21 View Post
Update all your drivers then give it another shot
No luck, everything was up to date or just updated. (Except updating to BETA Amd GPU drivers)
  #42 (permalink)
Old February 6, 2013, 07:19 PM
b1lk1's Avatar
Current setup, 2885 on the 1080p setting.
MY HEATWARE
  #43 (permalink)
Old February 24, 2013, 07:34 PM
b1lk1's Avatar
Added a HD 7950, score leaped to 6596, still not maxxed out too.
MY HEATWARE
  #44 (permalink)
Old February 25, 2013, 04:14 AM
I just keep getting a message saying that I've downloaded an old version.. :S
And for some reason my mouse has just stopped scrolling.. :(
  #45 (permalink)
Old February 25, 2013, 06:26 AM
great_big_abyss's Avatar
You have to go to their website and download the legit, updated version. The catch is that the only level of benchmark they allow to run for free is 'Cat'. You can't do Tiger, whereas before, you could.
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; Sapphire HD5870; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; ASUS GTX650Ti Boost; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
  #46 (permalink)
Old February 25, 2013, 06:43 AM
Nope.. still gives me the error.
DL from
http://www.allbenchmark.com/download
  #47 (permalink)
Old February 25, 2013, 07:39 AM
Bwaha.. sorted (after cleaning it out properly)
Got 12,796 in cat (I'll never pay for a benchmark unless my job or something requires it)
  #48 (permalink)
Old February 25, 2013, 01:43 PM
IRQ Conflict's Avatar
Cleaning what out? I had nothing but problems with earlier versions so I didn't bother with it.
I want to die peacefully in my sleep, like my grandpa. Not like the passengers in his car, screaming and crying.
  #49 (permalink)
Old February 25, 2013, 02:09 PM
it didn't remove everything(files and registry entries) when I uninstalled it.
  #50 (permalink)
Old February 25, 2013, 02:28 PM
Ah! OK. I did install it again. Got 10176. Weird bench.
Edit: 11307 CPU @ 3.8Ghz / GPU core@ 1200 mem@ 1670Mhz
ComputeMark benchmark burebista Overclocking, Tweaking and Benchmarking 1 April 18, 2010 06:37 AM
Tri Sli 280 n FC2 Benchmark rjbarker Video Cards 0 September 8, 2009 10:44 AM
Memory Benchmark enaberif Overclocking, Tweaking and Benchmarking 2 October 13, 2008 04:00 PM
New Benchmark! Prof. Dr. Silver Off Topic 11 January 15, 2008 11:51 AM
AquaMark 3 Benchmark Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 2 November 15, 2007 08:26 PM
