Old December 9, 2012, 09:46 PM
How long should I be running SmallFFT for?
In my previous post, I said that I tested with a 35 multiplier and 1.105 which failed in 10 minutes. I dont think that is suppose to happen is it? Stock is 34 at 1.100.
Old December 10, 2012, 05:36 AM
How long can you run. Smallfft for? If it errors out at all you need more voltage. Set the voltage for the cpu to 1.2 and start from 5here. Going from 1.1 to 1.105 is not a big enough increase.
Old December 10, 2012, 01:16 PM
your trouble shooting 1.25 isnt going to hurt the processor and 1.65 isnt going to hurt your mem and alot of those vipers had issues running at 1.5v esp the 2133 sticks some wouldnt even post at 1.5v the rated on box speeds. but were fine with more v.
the error your seeing is looking like ram to me so id try more v on mem first then try more v on vcore to the cpu 2nd.
also make sure your ram is defaulting to the correct timings.
My 3 current rigs
guest - Main - Work
I7 930@4.0ghz
3770K@ 4.8ghz
2500k @ 4.7ghz
SF101 HW BOT
Old December 10, 2012, 08:19 PM
How much voltage is too much for my processor?
I'll try bumping up my voltage for my RAM. Hopefully that will fix the problem. I checked, and my mobo is running the RAM at the correct timing :)
Old December 11, 2012, 04:25 PM
your looking at a upper on good cooling that is lets say 1.30v-1.35v or so for 4.5- 4.7 ish clocks after about 4.5 the voltage really seems to cause heat increases by larger margins.
i'm doing 4.8@ 1.33 but its getting a tad warm i wish i had a beefier cooler for it at these voltages and not every chip will do 4.8 at those voltages and some wont stabilize 24/7 for you at all most people settle at 4.5 with lower voltages.
My 3 current rigs
guest - Main - Work
I7 930@4.0ghz
3770K@ 4.8ghz
2500k @ 4.7ghz
SF101 HW BOT
prime 95 temperatures ravenger Overclocking, Tweaking and Benchmarking 10 April 5, 2012 08:33 PM
Error 101 (net::ERR_CONNECTION_RESET): Unknown error. chiknhawk O/S's, Drivers & General Software 1 April 30, 2011 05:08 AM
Update error code 8000ffff - unknown error hedgehog88 O/S's, Drivers & General Software 2 August 22, 2010 08:23 PM
BE 965 + prime 95 Prolab Overclocking, Tweaking and Benchmarking 0 August 6, 2010 04:46 PM
Prime 95 Error RogerzRig Overclocking, Tweaking and Benchmarking 52 February 20, 2008 09:03 PM
