Old December 4, 2012, 04:06 PM
r0k0's Avatar
Default Indigo Thermal Interface
anyone used this product before ?
i dont know if i've installed it properly but my temps are 10-15degres higher then before
Before : i5 2500K 5.0Ghz Dual rad with thermalright fans at max EK Supremen LT Nickel was running max 55-60
Now : i5 2500K 5.0Ghz, Single 120 with Thermalright, Sapphire 5970 Stock Clocks, Dual Rad with Thermalright all at max with EK Supreme LT Nickel now while gaming 70-75
could it be i installed the Indigo wrong or because my 5970 is making the CPU run hotter in the same loop ?
Main Rig
Intel Core i5 2500K - 5.0
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
AMD Radeon HD 6990 4GB 880 / 1300
Crosair 600T White / Enermax Revolution 920W
A-DATA 120GB SATA3 SSD / Seagates 1TB Spare SATA3
Canadian Eh ?
Old December 4, 2012, 04:47 PM
Is that the film of solder stuff that needs to be reflowed to seal your block to your cpu?
Old December 4, 2012, 04:57 PM
r0k0's Avatar
yeah it is
Main Rig
Canadian Eh ?
Old December 4, 2012, 07:26 PM
r0k0's Avatar
i've found a pdf on their site saying when using EK Supreme waterblock, not to tighten too much which i probably did, which will damage the ETI and to boot pc with pump on and once burn program has started to turn pump off.... which i didnt do and followed instruction from the box and boot with pump off.... guess that's why im overheating compared to before
Main Rig
Canadian Eh ?
[FS] Echo Indigo DJx ExpressCard Audio Card Jd007 Buy/Sell & Trade 3 April 16, 2012 06:20 PM
Indigo extreme kongfoo911 Water Cooling 6 June 3, 2011 09:23 PM
Indigo Xtreme Fudd Rucker Water Cooling 11 November 18, 2010 07:12 PM
Indigo Xtreme worth it over MX-3? JD Water Cooling 15 July 29, 2010 06:46 PM
Voltage regulator block (Thermal tape or thermal counpound?) Mavvens Water Cooling 5 August 8, 2009 06:56 PM
