-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   GTX 670 PE flawless (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/58086-gtx-670-pe-flawless.html)
ravenger November 24, 2012 04:38 PM
GTX 670 PE flawless
I got my 670 PE from msi about 3 weeks ago and i am not disappointed. It is so quiet even when playing games and the fans only really kick in on the stress tests like furmark and kombuster. On full load and running furmark for an hour it reached 67c and that is cooler than my 560 ti and the 670 is way faster.
clock speeds(with boost)
1319 mhz on the core
3304 mhz mem clock
I will be sticking with msi for a while if it keeps kicking out this performance. I could overclock more but this seems fast enough.
Pabz0r545 November 24, 2012 04:39 PM
Very nice. Can you do some 3d mark or heaven runs?
ravenger November 24, 2012 04:45 PM
Sure let me download them real quick and ill post results.
ravenger November 24, 2012 05:12 PM
Ok the score was 1160 with everything set to the highest it could go on a single 1920x1080p resolution.
Max frames 117 min 28 with a 46 fps average. I have no clue if this is good or not ive never used this program.
unigine heaven
Pabz0r545 November 24, 2012 05:18 PM
How about 3d mark 11? It's a bit better because you can just run the p score and compare to everyone elses p score. I could run a heaven mark right now but there are so many variables.
ravenger November 24, 2012 05:24 PM
installing now but its only the basic free edition ill have to look into getting the full version
yeah ill just have to get the full edition getting results at 720p seems like a waste of time
Pabz0r545 November 24, 2012 08:01 PM
The general test that everyone runs is the p score. It doesn't matter if it's 720p. You can use it to judge how it performs against other 670's.
ravenger March 27, 2013 06:49 PM
I forgot all about this post so my 3dmark11 score is p10230. Im working on getting to 10500 as I feel the card has more in it. Ive surpased stock 680's so I am happy but I expected it.
