-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   [3570k] First overclock, should I change anything? (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/57954-3570k-first-overclock-should-i-change-anything.html)
throbbingfetus November 18, 2012 07:16 PM
http://tinypic.com/r/123ab94/6
Is this alright? I ran for 5 hours and everything seems to be stable.
Pabz0r545 November 19, 2012 06:47 AM
Picture link is broken .
summak November 19, 2012 02:46 PM
for overclocking, I always did a 24hr stress test, although its too much, but thats what I do wen i OC something. Check the temperature also, and make sure its in the safe zone, it will depend on the processor over here. Do enough cooling if you think its too hot.
And yea, 24hr test run.
dandelioneater November 19, 2012 03:14 PM
Try some folding on the chip to truly test its stability. There is no better test. Do a few days of folding and if you work units are completing, then you are stable.
blueem2 November 19, 2012 06:50 PM
Picture is broken. I can get 4.2 GHz on my 3570k without any problems at all. Temps hover around 60 degrees celcius. Where I start to run into trouble is 4.5GHz+ because temps start to reach 80 degrees. I don't like going that high. Mine is not a good overclocker however.
DarKStar November 20, 2012 07:23 PM
I can OC fine on air cooling up to 4.3Ghz, without overvolting. I would not recommend using auto tune OC or auto OCing as they might unecessarily OV your CPU and that will cause them to run very hot. It's best when reaching higher OCs to do some manual tweaks. For sure I would not push any higher on a stock HSF, stock volts. You will need a good AMC if you want to push higher, stable and higher voltage. Also each CPU will vary. Mine runs rock solid and stable at 4.3Ghz, stock V. There is really no reason to OC that CPU, it will handle all latest games fine at stock settnigs and 3.8Ghz Turbo, just get a decent GPU, the FPS will be great, the extra few FPS will not even be visible and really not worth running your CPU any hotter. I would not OC this CPU unless doing some long rendering, etc, to justify saving a few minutes/hours in the long run, but not for games, not worth it.
