-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   msi afterburner or nvidia software (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/57664-msi-afterburner-nvidia-software.html)
ravenger November 2, 2012 06:43 PM
Ok I got an msi gtx 670 and I am just playing with clock speeds and stuff. I got the clock speeds in msi afterburner right where i want them but, the problem is nvidia performence, fermark, and gpu z are reporting deferent speeds than what i have set in msi afterburner. Its following the clock speeds set in the nvidia performance menu and i dont know how to follow afterburners settings.
resolved
mleunm November 3, 2012 09:13 AM
I have never used any other softwhere except the nvidia drivers anything else is just another layer on top of the drivers...my two cents
supaflyx3 November 3, 2012 09:26 AM
Are these under load? IIRC the 6** series don't clock up until it's needed and within the power requirements set.
enaberif November 3, 2012 09:30 AM
resolved
go into nvidia control panel and change the performance setting from adaptive to performance
ravenger November 3, 2012 02:16 PM
Ok, so furmark and kombuster report 1319mhz core and the correct memory but gpuz is still reporting the wrong core speeds, mem speeds, and boost speeds. When i run furmark or kombuster then check gpu-z sensors it says max speeds were 1319 mhz core and and 1652 memclock which is correct. Still in the gpu-z main menu which shows all the graphic card info it says its set to 1125 gpu clock and 1203 with boost. The mem clock is correct though with 1652. Gpu-z and nvidia control panel are the only ones that read different speeds than what i have set in afterburner so far.
