Manually Setting RAM My new ASUS MBoard F2A85-M PRO does not recognize my Kingston Hyper X RAM as 1600, setting it up as 1333 instead. I went into the SDRAM Section in the ASUS Bios program and I can see the various settings but a) am not sure what I would change - I have a print out of the spec sheet but the specs on the screen do not match the specs on the sheet which are very scant, http://www.kingston.com/datasheets/KHX16C10B1RK2_16.pdf And B) the program only lets me change two of about a dozen settings, the rest are set to 'auto' and when I click on those auto's nothing happens. I also looked in the ASUS Ai program which runs in Windows - but did not find any place there to change the RAM settings. I paid for 1600 Mhz, I'd like to get 1600 Mhz - more if I can. I did just upgrade to Windows 8 Pro - my Windows 7 Home Premium did not support more than 16 GB Ram. |
First a question, how many of those 8 gb ram stick you install in your PC ? I ask because if you have 4 sticks you have to increase certain voltage too also take note that anything over 1333 is OC even if the motherboard support faster ram, so they are no warranty that will work. |
Getting to 1600 Mhz on Kingston Hyper X RAM Quote:
32 GB of ram on a Hudson board :doh: wtf you need 32 gb for in a such build ? 32 gb of 8 gb stick it's a mix for failure anyway, I have no experience with increasing the voltage on Hudson but on a regular AMD and Intel you have increase the dram voltage and sometime other voltage too. You see when you put more sticks it drain more current and it make the voltage drop, it's why you have to increase the voltage. Search in the BIOS Dram voltage and rise it from 1.5 to 1,6 slowly until you reach something stable. But if you ask me , sell those ram and go with 2 x 4 gb it's plenty , if you need more, you probably need a better CPU anyway |
There should be a setting in bios for memory frequency which will allow you to select 1600, but as already stated, with 4 sticks on an AMD platform, don't be surprised if you have to bump the Dram and NB voltages up a little from stock in order to get them stable. A quick check would be to remove two sticks to set your bios and then stress test the mem with the two sticks. If that works fine, install the second set and run your tests again, if its stable then great, if not then you know you need to bump the dram voltages up a bit. Do yourself a favour and download CPU-Z in order to check what the SPD of the memory is supposed to be so that you have a better idea of what settings to look for. |
Check for the AMP (AMD Memory Profile) in your bios DRAM Settings. This should give you the option to run at 1600MHZ. |
After installing CPU-Z I was able to see that the RAM is operating at 1600, it still reports the SPD as 1333 but I guess that is normal. It did work I just didn't know it was working. |
| All times are GMT -7. The time now is 09:27 PM. |
