Overclocking for Beginners? I'm sure you guys have seen many similar threads, but i honestly don't know what to do. I've gone through a one month RMA Process for my GPU AND MB (not my fault and nothing to do with OC) so i'm scared that I'll break another thing. I want to overclock my CPU, but the only thing that scares me is overheating and or frying my whole system. Anyone have an easy guide to follow? Or does someone already have any good settings i should use? If possible, i want to aim anywhere from 4-4.5 GHZ. I dont need more than that. System Specs: ASUS Sabertooth Z77 MB Intel i7 37770K CPU MSI R7950 3GB OC GPU 16GB Corsair Vengeance Low Profile Ram HAF X Case Noctua NH-d14 CPU Cooler I dont think i need to list anything else, if so, let me know. |
well my self am a noob at OCing and I just go slow, it takes time and patience the worst that has ever happened to me was the BSOD when I reach that point I back off a little then I do some stress testing using some tools that are posted here http://www.hardwarecanucks.com/forum...ols-trade.html as for heat I am not sure what the average high underload temp is for that CPU |
Hi there, i just downloaded this software "cpuid" and i noticed something that might be a bit odd. It states the following: Core speed: 4223.78 MHz Multiplier: x 41.0 Bus Speed: 103.0 MHz Core Voltage: 1.000V Isn't this supposed to be at 3.5 MHz? I don't remember touching anything. I do, however, have this turboV software from ASUS, but as far as i remember, i haven't touched it at all. |
here is a page of info for the cpu here Intel Core i7-3770K - CM8063701211700 / BX80637I73770K / BXC80637I73770K maybe try this program CWID.exe I am sure it is on the same above sight |
Reset your bus speed to 100.0 and leave everything else on auto. Then change your multiplier from 35 to 40. Chances are it'll just work. |
shut off your Intel turbo boost fool :p Then run hardware monitor , what's your temps ? my 3770 is running 5.0ghz multi x50 voltage 1.4 turbo core off does have heat spikes here and there though but works great on upgraded cooling |
Here are some screenshots: http://www.hardwarecanucks.com/forum...e982-cpuid.png http://www.hardwarecanucks.com/forum...-hwmonitor.png Edit: I don't want to go to 5GHZ, just 4.5GHz so what should i do in BIOS? |
Try 45 multiplier and 1.3vcore. |
Check out my bios screens: http://i1112.photobucket.com/albums/...h_IMG_0472.jpg http://i1112.photobucket.com/albums/...h_IMG_0473.jpg http://i1112.photobucket.com/albums/...h_IMG_0475.jpg You'll want to also go to digi+ power management under the cpu section and adjust load line calibration to at least the second highest. Then make sure that your memory timings and DRAM voltage are what they are supposed to be. everything else should be defult or auto. then save, boot into windows, and test for stability using OCCT. Prime 95 and LinX stress these chips pretty hard and they say it may not be good for them. |
| All times are GMT -7. The time now is 03:32 AM. |
