Old October 7, 2012, 11:30 AM
Shadowmeph's Avatar
I know that this has nothing really to do with OCing but I am curious as to why the temps between cores is so different core 1 is 43 and core 2 is 36 does that matter .
Folder :
ASUS KGPE-D16 Dual Socket G34, 8x2GB kingston1333MHz DDR3, 2x 6i28 CPUs 2x NH-U9DO A3
Old October 7, 2012, 12:17 PM
Originally Posted by dandelioneater View Post
Check out my bios screens:
You'll want to also go to digi+ power management under the cpu section and adjust load line calibration to at least the second highest.
Then make sure that your memory timings and DRAM voltage are what they are supposed to be.
everything else should be defult or auto. then save, boot into windows, and test for stability using OCCT. Prime 95 and LinX stress these chips pretty hard and they say it may not be good for them.
Hey, i set my settings just like you had in the screenshots ( i don't know if you wanted me to do that) and i also checked the timing and voltage for the RAM. Unfortunately, however, my PC failed to start. I went into bios, reset to defaults and now im up in running. I am, however, running at 3.8ghz now :/
Old October 7, 2012, 01:07 PM
Shadowmeph's Avatar
well if your PC failed to start then you need to drop the multiplier lower then 45 , like what perineum mentioned
Then change your multiplier from 35 to 40.
usually you just leave every thing alone except for the multiplier inwhich you bump that up a little at a time until you get a failed boot, then you adjust the multipler down until the PC does start when you get to the desk top you stress test after a fair amount of time of stress testing( myself I am impatient so I usually do other things on my PC at the same time ) as stress testing and monitoring your heat if everything is to your likeng then your done if you want to tweak it out to get every little bit out of the motherboard and cpu then it can get tricky.
myself most of the time I just use the asus automatic overclock , then I slowly play around to get a higher stable clock
Folder :
Old October 7, 2012, 01:32 PM
dandelioneater's Avatar
Not all chips are equal so what voltage works for me may not work for you. I would start by disabling speed step, c-states, spread spectrum, and any other intel power saving feature you can find. Save reboot, see if it posts. then go in and slowly increase the multiplier saving and rebooting to make sure it will post. These chips get hot when you go past 4.6GHz and 1.3V so i chose 4.5 as my 24/7 overclock. Start with 1.3V and slowly work your way up to the 45X multiplier. Once there you can run stress tests and reduce the voltage to get it as low as possible.
Old October 7, 2012, 01:39 PM
Shadowmeph's Avatar
man I sure wished my system ( AMD) could clock to that I am lucky to get to 4 Ghz stable which is why I am really considering going to Intel
Folder :
Old October 7, 2012, 01:46 PM
well, IB chips are considerably newer, and generally run cooler than 1100T's, but I think a 6 core chip at 4GHz is still very good for todays applications. The equivalent intel chip would still just be a 920 or 860/750 and they will clock to those same speeds; not much higher for 24/7 use.
I'm not sure you need to go intel to get high clocks. The 8 thread Bulldozer will clock to 4.5+ GHz.
Old October 7, 2012, 01:48 PM
Your_friendly_gamer's Avatar
Just use Asus built in overclocking utility. If you are not sure what you are doing, thats the best to use. And they are pretty good when it comes to software overclocking. here it is under utilities under downloads for your mobo:
ASUS - Motherboards- ASUS SABERTOOTH Z77
That's the best advise I will give you. it will auto boost you to 4.0ghz plus! and good luck
Old October 7, 2012, 03:43 PM
Perineum's Avatar
Asus recommends not doing that with these newer socket CPUs, they claim it makes no difference in overclocking at all but just makes you use more power
Socket 775 sometimes needed speedstep disabled, etc.
Beginners Guide on how to piece together a Custom WaterCooling Kit Apollo4g Guides & How-to's 21 August 13, 2011 05:10 PM
How to Choose and Install a Capture Card for Beginners Mr. Gruntsworthy Guides & How-to's 0 February 12, 2011 10:27 PM
Needs some help overclocking lanken123 Overclocking, Tweaking and Benchmarking 0 April 21, 2009 11:51 AM
Overclocking help tzetsin Overclocking, Tweaking and Benchmarking 41 January 27, 2008 11:05 PM
Need help overclocking further Kessler Overclocking, Tweaking and Benchmarking 15 December 5, 2007 05:09 PM
