  #51 (permalink)
Old March 12, 2013, 10:36 PM
IRQ Conflict's Avatar
reseal the IHS
What do you plan on using for this?
  #52 (permalink)
Old March 12, 2013, 11:41 PM
turtletrax's Avatar
Most likely black rtv silicone. I figure just a dab in each corner just so the IHS doesn't slide around when latching.
"It's time to kick gum, and chew ass. And I'm all out of gum."
Dick Kickem
  #53 (permalink)
Old March 13, 2013, 07:12 PM
MVG 0904, i7 3770K de-lidded with CL Liquid Pro, open air setup:
45x100, 1.288V in CPU-Z, ~70C load on Corsair A50 with NF-P12 on "Silent" mode in BIOS.
46x100, 1.350V in CPU-Z, ~80C load on Corsair A50 with NF-P12 + NF-P14 both on "Silent" mode in BIOS.
I'm testing on a crappy, noisy Lite-On 300W PSU which buzzes under load and drowns out the fan noise.
In contrast, the delidded one I purchased from ontariotl is running
P8Z77-V Pro, i7 3770K de-lidded with CL Liquid Pro in Antec NSK4480 with GTX680 and a slow 400RPM NF-P12 exhaust and AX750 PSU:
45x100 1.30V in CPU-Z ~80 load on a HR-02 macho with a 450-500 RPM NF-P14
Inaudible from operating position. Tower is placed under my desk.
Once I find a backplate for my NH-D14 I'll swap it in place of the A50 open-air setup and see what the temperature difference is.
heatware
  #54 (permalink)
Old May 2, 2013, 07:39 AM
Hinouchie's Avatar
So compare to 2600k Sandy, 3770k Ivy they would overclock the same? well beside the heat issue.
I just got my 3770k, gonna test out how HOT ivy will be going 4.5GHZ on air.
  #55 (permalink)
Old May 2, 2013, 07:53 AM
If your aim is 4.5 GHz you won't have an issue with either SB or IB.
From my experience if you want higher than 4.5GHz you will need to dump a lot more voltage into IB. All of my old 2600K's hit 4.8GHz at less than 1.4V.
Also to update my last post, open-air cooling improved by about 2-3 C with the NH-D14 vs A50. Not worth the price difference at all.
heatware
  #56 (permalink)
Old May 2, 2013, 08:02 AM
Hinouchie's Avatar
I can hit 4.5GHz without problem on my 2500k at 1.37v
I got the hyper 212+ pull on the 3770k right now, saw some comparison online and it doesn't do that well during full load. Might get my hands on an NH-D14 or phanteks ph-tc14pe.
  #57 (permalink)
Old May 2, 2013, 08:11 AM
Soullessone21's Avatar
Maxed a testing board out last night that maxes out at 1.35V at that point I can get the 3770K to run at 4.7Ghz with minor stability issues or at 4.6Ghz for day to day never going above 60c on a cheap AIO.
Get a AIO water cooler
Good Bye HWC it was great :)
Site and Forum:
http://forums.realhardwarereviews.com/index.php
If you need me the link above is where I spend my days now
  #58 (permalink)
Old May 2, 2013, 08:58 AM
Hinouchie's Avatar
I did though about getting AIO watercooling, but for price / performance, the phanteks ph-tc14pe > all.
AIO watercooling vs phanteks ph-tc14pe is only 2-5c difference but in price wise, $130+ vs $89+
  #59 (permalink)
Old May 2, 2013, 09:02 AM
Where do you live??? I have seen good AIO for as low as $40 its called the Bargain bin at NCIX and Memoryxpress
Site and Forum:
  #60 (permalink)
Old May 2, 2013, 09:14 AM
Hinouchie's Avatar
I'm talking about the top end AIO so yea they're at 100+ range :P Which one are you using?
is this ram good for i7 3770 k yehia7000 RAM 9 September 9, 2012 10:27 AM
i7 3770 k overclocking problem yehia7000 CPU's and Motherboards 3 July 24, 2012 08:16 PM
UGH, damn you HTC! LarkStarr Mobile Computing 2 April 13, 2011 06:33 PM
Damn.. Soultribunal HardwareCanucks F@H Team 19 December 11, 2009 05:47 PM
Damn it shaw! Phobia Networking 14 April 1, 2009 01:00 AM
