-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   i7 970 overclocked with XSPC 360 RS KIT (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/56425-i7-970-overclocked-xspc-360-rs-kit.html)
TRI-MIX August 30, 2012 12:22 PM
looking for anyone who has an i7 970 overclocked with XSPC 360 RS kit with a corsair 800d case !
Looking for TEMPS @idle and FULL load
-And what fan's are you running
-Push pull
_And what fluid is in the rad !
Thanks TRIMIX
Fudd Rucker August 30, 2012 12:32 PM
I have a mighty similiar setup. Cpu is @ 4.4ghz
XSPC 360 rad on an EK gpu and cpu block.Using 3 Scythe Kazi 3000rpm@ 35% fan speed in a pull config.
Loop order is -> Pump -> gpu -> cpu -> rad -> res.
My temps are : GPU under load doing einstien@home 59 degrees , cpu under load is about 72 degrees. Im using just straight distilled water with the swiftec hydrx additive.
TRI-MIX August 30, 2012 03:51 PM
Thanks ... Will be fishing the computer soon.. Still waiting on the kit to get here ! just looking for reference temps .
i have the cpu overclocked now on a h70 3.8ghz idle 28c full load 57c
Hoping to drop that a lot with the new water cooler
Thanks trimix
