-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   Some novice GPU OC questions. (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/56355-some-novice-gpu-oc-questions.html)
PaperOrPlastic? August 27, 2012 05:28 AM
Hey all, I recently replaced my two 6950's for an EVGA GTX 680 4gb edition.
Stock clocks are at a base of 1019, and a boost of 1110. I downloaded EVGA precision X and and have been slowly tweaking in intervals of +5mhz for a while now. Testing with the built in burn in test, and heaven bench to make sure its stable over longer periods of time.
I have gotten the boost clock up to 1290mhz stable. Sort of.. My official stable clock was 1250mhz. That was acheived and gamed on with a power target of 135%, plus 150mhz boost clock and +500mhz on the memory. All worked with that.
With the 1290mhz boost OC if I raise the memory the OC doesn't work and TDR kicks in, if I leave the memory at its base clock and power target at 125% it seems to be stable.
I guess my question and point is that I am not too experienced with overclocking in general and I am not sure if I am doing something wrong and that is why I cannot reach my desired clock of 1.3ghz, or if it simply this chip I have gotten is not capable for whatever manufacturing reason.
Under load the temperature gets up to 64 degrees, I set my own fan curve to keep the thermals lower and its working out great. A little noisy but I don't mind.
So anyone have any tips to get more out of this card, or have I hit its limit?
I believe my rig is in my sig for those who need to know.
EDIT: Ok so as of now the only stable OC I have achieved is 1250, and 500 plus memory at 130% power target.
KaptCrunch August 27, 2012 06:12 AM
next step is peltier cooling on gpu to silence the fan curves
