Over clocking phenomx6 1100t BE.... My pc spec: cpu:phenom x6 1100t BE. gpu:Palit gt 220 1gb ddr3. psu: cooler master extreme power plus 650 watt(RS-650-PCAR-E3). ram:zion 1333 mhz 8 gb. mb:jetway hummer HA12-LF. sound card:creative sound blaster 5.1 vx. hdd:samsung 500gb (model HD503HI ). cpu cooler : cooler master hyper 212 evo with 2 fans in push pull config. my current temps cpu ideal : 27 degrees C. mb ideal: 40 degrees C. cpu average : 33 degrees C. mb average : 44 degrees C. cpu 100% : 55 degrees C. mb 100% :64 degrees C. i want to overclock to 3.6 all the 6 cores. |
Is that pre overclock? those load temps are high even if it is OCed to 3.6. Something is not right. - Is there a dust bunny trapped in the heat sink wishing for it all to end? - Thermal compound applied right? I have not used that cooler specifically but almost any after market cooler should get you at least 3.8Ghz on that chip and stay around 50C under load. |
Do you know your way around the bios at all? Since it's an ulocked processor, and you're not really shooting for a high OC you should be able to just bump the CPU multiplier up a notch without having to do anything with the voltage and/or memory settings. Anything other than a straight cpu mulitiplier bump and you're going to have to start watching your memory as it probably doesn't have a lot of headroom. And yeah... your temps seem high unless you happen to be in an area with extremely high ambient temps and no ac. |
sorry guys about my wrong informations on cpu & mb temps the temps on 100% load on 3.3ghz are cpu:46 degrees C. mb:54 degrees C. done amd stability test for 30 min. |
that should be a very easy OC to do , I could never get mine past 3.8 and running smooth. but 3.6 is like one bump. |
does overclocking reduces the life of the cpu. |
Honestly 3.6 is what that cpu will probably run at if all the cores arent stressed (mine did till i locked it a 3.3). You wont notice the small increase in speed from 3.3 to 3.6... So no the OC you want wont hurt it at all |
so what are the steps to overclock. |
all i did for this computer was set the multi to 20 and put the voltage to 1.4 pretty good i'd say heatsink is a coolit eco ALC http://images.ncix.com/forumimages/1...5A157DA07B.jpg |
go into the bios and increase the multiplier. its 200 x multiplier = cpu frequency. 3.6 ghz should be a no hassle overclock, so you should be able to go in the bios and change the multiplier to 18. |
| All times are GMT -7. The time now is 06:59 AM. |
