  #31 (permalink)
Old August 25, 2012, 07:01 AM
BlueByte's Avatar
Yeah your oc looks fine, temps are fine. If those are true idle temps you may want to look at air flow in your case but honestly it looks like you are stable. My idle temps gets close to room temps.
  #32 (permalink)
Old August 25, 2012, 08:40 AM
thats because you are using ******H100******
and mine CM hyper 212 evo lots of difference from performance & price aspects.
  #33 (permalink)
Old August 25, 2012, 08:48 AM
BlueByte's Avatar
LOL yes the H100 will outperform on the load temps, but idle should be pretty even across the board since the chips are not working hard and will be producing very little heat. Anyways your idle temps are fine, just if you wanted to improve anything, I would say air flow in the case.
  #34 (permalink)
Old August 25, 2012, 09:21 AM
BY THE WAY WHAT IS THE PRICE OF H100 .
  #35 (permalink)
Old August 25, 2012, 09:36 AM
BlueByte's Avatar
Around $100 I think, honestly if you don't have the case to do a 4 fan push pull the H80 is a easier fit and not a lot worse.... or if your willing to stick a giant brick on, the Noctua NH-D14 comes on sale for $50-60 I think. I need to update my system specs here, but every case I have had since the H100 has required me to mod to be able to stick 4 fans on it. I have a Antec P280 right now and it hits the ram slots on the top with 4 fans.
  #36 (permalink)
Old August 25, 2012, 01:10 PM
what about antes kulhar 920 vs h100 vs nhd-14.
  #37 (permalink)
Old August 25, 2012, 03:29 PM
BigPhatPaulie's Avatar
The all in one watercoolers will perform about on par with the noctua mega tower. They are lighter and take up less space however and if you replace the stock fans they get even better.
FOR PONY..... that is alll
  #38 (permalink)
Old August 25, 2012, 04:09 PM
I tried to over clock to 4ghz but failed. what is the reason is my processor weak .
  #39 (permalink)
Old August 25, 2012, 06:37 PM
BlueByte's Avatar
Depends, if you are around 50C at 3.8 you are prob not going to hit 4Ghz on your cooling. Your temps get out of control, the higher your temps the more volts you have to pour into it to keep it stable. The AMDs run better and on less volts the cooler they run. This is assuming you are not trying for any world records, and from my own personal experience.
Just take baby steps, maybe bump up 50mhz at a time and play with voltages a bit if you have to, try to increase as little as possible and let it boot and test for stable, repeat until you can't go any higher and stay stable, then back off a bit(25mhz) and test again.
if you get there 1.5V is safe to hit if you are keeping it cool, but if its going to hit 4Ghz it will do so on less than that and stay stable.
That's my experiance with them anyways, I had a 1055 stay cool at around 40 under load that would not go above 3.8Ghz. Its a gamble when you overclock. The reviews you read online a lot of the time have to be cherry picked pieces. I have very rarely hit the review OCs on my own equipment.
  #40 (permalink)
Old August 25, 2012, 07:12 PM
at 3.8 ghz my system boot im windows 7 the temps were 34-36 ideal and when i started stability test it showed a error i.e creating dump files and rebooted it self.
may be that went wrong because i suddenly increased from 3.6 to 3.8 ghz.so there is no processor issue are they.....
ASUS Crosshair Formula V/ 1100T norfolk Price Check 4 June 5, 2012 08:09 PM
[WTB] Fx-8120/Fx-8150/x6 1090t/x6 1100t lilmoja Buy/Sell & Trade 5 May 1, 2012 08:04 AM
Marginal upgrade with AMD 1100T? moocow CPU's and Motherboards 2 February 15, 2012 08:06 AM
phenom ii 1100T overclock mavriskia Overclocking, Tweaking and Benchmarking 4 December 3, 2011 08:58 AM
[WTB] need a motherboard for an 1100t x6 _dangtx_ Buy/Sell & Trade 0 August 21, 2011 03:55 PM
