  #21 (permalink)
Old August 24, 2012, 05:36 AM
ok i will try and update soon ..
  #22 (permalink)
Old August 24, 2012, 05:42 AM
Bloodystumps's Avatar
ok like I said I misunderstood the way your BIOS was set up , and I probably shouldn't have replied so early in the morning set the multiplier to 18 and see if its stable and if you have a good CPU cooler and you want to get it higher bump those settings ..
processor voltage AUTO. set it to 1.4v and if its not stable bump in small increments
the other two move only if you are getting unstable and only move one increment at a time IF IT'S unstable .
and as always read on as much information as you can on , in particular the motherboard settings and what each setting does .
ok after reading the manual what the hell is 7 shift ?
CPU Vcore 7-Shift--- (Shift to Higher Performance)
The CPU voltage can be adjusted up by 7 steps for the precisely over-clocking of extra demanding
computing performance.
I am reading the manual for that motherboard now .
  #23 (permalink)
Old August 24, 2012, 07:14 AM
i did what you said, now its ok.
(i changed only cpu multiplier to 18 & rest in default. )
now should i run stability test to check stability of cpu , if yes (probably yes) for how many hours.
  #24 (permalink)
Old August 24, 2012, 01:12 PM
i already ran a 100min stability test with no issues, it is enough or not...
  #25 (permalink)
Old August 24, 2012, 01:29 PM
dandelioneater's Avatar
Did you use Prime95? 100min might be 'stable enough', but you really need at least 6 hours or more of prime to be really sure that the overclock is rock solid stable. Folding@Home is another good test too.
  #26 (permalink)
Old August 24, 2012, 01:43 PM
no,amd overdrive's stability test.
  #27 (permalink)
Old August 24, 2012, 01:51 PM
sorry forget to mention about temps
on 100% cpu: 48 degree C & mb: 56 degree C.
is it ok
  #28 (permalink)
Old August 24, 2012, 08:12 PM
run prime 95 for 1hrs temps 50 no warning no errors.
  #29 (permalink)
Old August 25, 2012, 05:38 AM
your good to go. If you start to get issues later you can deal with it then, but I doubt you will...that is a pretty common OC for that CPU.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
  #30 (permalink)
Old August 25, 2012, 06:23 AM
previous ideal temps 27 now 30 is it ok.
ASUS Crosshair Formula V/ 1100T norfolk Price Check 4 June 5, 2012 08:09 PM
[WTB] Fx-8120/Fx-8150/x6 1090t/x6 1100t lilmoja Buy/Sell & Trade 5 May 1, 2012 08:04 AM
Marginal upgrade with AMD 1100T? moocow CPU's and Motherboards 2 February 15, 2012 08:06 AM
phenom ii 1100T overclock mavriskia Overclocking, Tweaking and Benchmarking 4 December 3, 2011 08:58 AM
[WTB] need a motherboard for an 1100t x6 _dangtx_ Buy/Sell & Trade 0 August 21, 2011 03:55 PM
