Old August 12, 2012, 05:37 PM
Default Intel SpeedStep not working on Intel DP67BG Extreme Board!!! please help
Guys.....
As some of you may now I recently upgraded to a brand new system and have been using gaming with an overclocked Core i5-2550K processor to 3.8 GHz and using Corsair Vengeance RAM at 1600 MHZ. Since I am using an Intel DP67BG Extreme motherboard, I used the Intel Extreme Tuning Utility to OC my processor. I simply increased the CPU multiplier to 3. 8 GHz on each core and nothing else. Yesterday something weird happened however. Both CPUID-CPUZ and CoreTemp indicated that even while idle, my processor would not downclock to 1.6 GHZ( which it did until yesterday) even though I have had Intelīs SpeedStep feature enabled from the Extreme Tuning utility's Manual Tuning panel since I first OC my CPu. So basically my processor operates at 3.8GHz even when not doing anything and core voltage levels now oscillate between 1.2800 to 1.3200 even if am just surfing the web.
I am very worried that I might have damaged some internal regulation system in my motherboard or perhaps something worse. I would really appreciate some advise on what could be causing this situation and whether it is safe for me to continue using my processor in its overclocked state.
Many thanks for your help
Old August 12, 2012, 06:55 PM
Delavan's Avatar
I don't know for your particular board, but there is several options you can tweak that will alter the speedstep...so reset your board's settings and start again...write all settings down...there is a right combination of settings that will OC with the downclock working proper....
On my Asus board/2500K, I disable all that, and I get a steady 4.5Ghz clock even at idle...I prefer it like that myself....
Remember, lowest temperature and lowest voltage for a stable OC is what's matter...
I find the downclocking features are nice for laptops (to save every bit of electricity), but for an overclocked rig, I find it's ALMOST pointless.....
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
Old August 12, 2012, 07:34 PM
Thanks for you comment dude.
I appreciate your advise but must say that I do want to have SpeedStep on just because it allows me to use less power and, I'll admit it, likes to save power whenever I can( even when overclocking) But i will see waht resetting my BIOS does will let all you guys know
Old August 13, 2012, 04:28 PM
Ravenor's Avatar
Reseting all your setting is a good idea(so long as you write down what you had before you change them). You can also see if there is an upgrade to the Bios that might fix any potential problems that Intel may have coded into the original Bios.
This is the lastest, but BEWARE AND READ THE DISCLAIMER!!!
http://downloadcenter.intel.com/Deta...=3273&lang=eng
This is suppose to be unreversable if you upgrade...why I have no idea. but it did come out 7/17/2012.
I Feel Amazing Expendable! - Misc. Imperial Guard
Old October 21, 2012, 05:15 PM
Rassal's Avatar
Just make sure you don't use the high performance power profile (use the balanced one, and tweak it) on windows 7, as it disables speedstep.
Rampage IV Extreme (3301) + Core i7-3930K @ 4.3GHZ + Corsair H100i Push Config.
VCore = 1.33v | LLC = Auto | VTT = 1.10v | 2nd VTT = Auto | VCCSA = 1.10v | PLL = 1.78125v
G.Skill Ripjawz Z 32GB DDR3-1866 @ 1866 (8x4gb) Using XMP profile#1
Dual Corsair Force GT 120gb Raid-0 Sata 6G RSTe + 1TB WD Blue Sata 6G ASMedia
Dual Sapphire Radeon 6870 xfire - Cooler Master Cosmos II Case
PC Power & Cooling Silencer MKII 950w power supply.
Dell 2709wfp LCD Monitor (1920x1200) - Windows 8 Pro x64
Overclocking i5-2500k in an Intel DP67BG Extreme MB sankukai Overclocking, Tweaking and Benchmarking 10 May 2, 2012 09:22 PM
775 intel board for gtx480 sli? gray mole CPU's and Motherboards 14 December 30, 2010 11:43 PM
[WTB] Non working Sata DVD/CD rom and Intel Gigabit adaptor Prolab Buy/Sell & Trade 8 December 17, 2010 11:44 AM
is Intel working on an other 1366 chipset ? MarkOne CPU's and Motherboards 14 January 25, 2010 04:31 PM
[WTB] MATX BOard INTEL 775 elec999 Buy/Sell & Trade 1 November 27, 2008 11:23 AM
