Old July 7, 2012, 12:22 AM
Default GTX 670/680 Kepler OC thread
1. What card you are using?
2. What is your OC?
3. What is your ASIC?
(ASIC can be checked on gpu-z by clicking the top left corner to get the drop down menu)
I'll go first, considering I am the one starting the thread.
1. Gigabyte GTX 670 Windforce (probably the worst one to have made it past their quality control too, so I must get points for this right?)
2. 1059Base/1138CertifiedBoost/1202MaxBoost/6804Mem
3. ASIC: 89.0% ! ! !
Old July 7, 2012, 03:18 PM
GT7R's Avatar
89% ASIC quality is actually not bad at all.
Old July 7, 2012, 03:36 PM
compared to video cards in general yeah (my old 580 was getting 57% so yeah) but from what I've gathered most keplers are in the 98-100% range. guess it has something to do with the new 28nm process, also the fact that you get no voltage control makes it a disadvantage!
Old July 7, 2012, 03:38 PM
Both of mine have 100%. I haven't OC'd them though is that why? I haven't bothered to test out my OC on the MSI as it easily hits over 70 degrees in SLi and downclocks. Waiting till I get these puppies under water.
Old July 8, 2012, 01:42 PM
Default 64 Bit MSI Afterburner
Is there such a thing?
All I can seem to find is the 32 bit Ver
Thanks Fuz
Old July 8, 2012, 02:21 PM
680 Gigabyte reference card, have it under water under a EK block. It turbos at 1320~ Max Load temp 41c
ASIC is 100% as well
Old July 18, 2012, 01:00 PM
ok got a 2nd Gigabyte GTX 670 OC and I have no clue what is up with my luck....
ASIC at 82.8%...the card wasn't even stable stock until I updated the bios (still can't OC it though as anything higher than stock still isn't stable on the core).
What is up with my luck?
Update: the memory seems to be quite impressive considering how bad the gpu is. I'm getting it stable with no problems at +570 (didn't try any higher as I stopped seeing noticable performance increases after the +500s).
Old July 19, 2012, 11:12 PM
Dzzope's Avatar
Asus 670DCII (not top)
ASIC is 100%
GPU clock: 1092
Memory: 1584
Boost: 1157
No idea how to see the Max boost.. lol
Bios version is 80.04.19.00.17 compared to some others here with end of 54 or 70.. worth updating?
Old July 20, 2012, 09:00 AM
I wouldn't unless I was getting problems...(which I was with the 2nd card)
forums.overclockers.co.uk thread on people with the Windforce GTX 670, their ASIC and their OC. From the looks of it either I have the worst luck of all with 2 of the most terrible cards, or there is something in the production and distribution pipelines that makes it so that the retailer where I bought mine (NCIX) get the worst batch of them all...
People reporting stock boosts of 1200mhz, while my first card could barely do this at max barely stable OC and the 2nd card can't even OC and gets boost of 1086mhz...(cooling is not an issue as these cards never get past 62-63C).
Old August 10, 2012, 05:08 AM
Default GTX 670 Unlocked Voltage Bios
I have a Windforce 670 I am considering flashing to the L2 Bios has anybody tried this & if so is it worth it?
I am presently sitting @ +112 on the gpu & +258 with the memory
Thanks fuz
kepler and folding Pabz0r545 HardwareCanucks F@H Team 2 June 26, 2012 10:29 AM
NVIDIA Launches Kepler Based GPU For Laptops Sam_Reynolds Press Releases & Tech News 0 June 5, 2012 12:07 PM
Nvidia Kepler & Tegra stuff... Grampa Rumor Mill 93 May 8, 2012 11:16 AM
Worth waiting for Kepler? 7870 good enough? BukitHedd Video Cards 13 April 2, 2012 07:14 PM
Spire Announces Kepler Series Universal CPU Coolers Sam_Reynolds Press Releases & Tech News 0 October 10, 2011 10:11 AM
