Old July 5, 2012, 04:59 PM
Your_friendly_gamer's Avatar
Default HELPPPPP! Please help me oc my I7 960 with a X58A-UD3R board
I need help please, this is only my 3rd set up and never really oc'd 1366 manually before. Always did auto oc. Has anyone had any experience with this set up? similar to mine?
I7 960
X58A-UD3R
3x2GIG Mushkin Redline 6-8-6 24 2T
Thanks
Old July 5, 2012, 05:05 PM
supaflyx3's Avatar
Guide to Overclocking the Core I7 920 or 930 to 4.0ghz
Thats for a 920, but the basics are the same.
Old July 5, 2012, 05:14 PM
ZZLEE's Avatar
multi 21
QPI 198
V cpu 1.34
pcie +0.5
Ram 1.60 V
Set Ram timings manuly
Ram at 2:8
see what happens
fans at 100 %
then ajust to :
40 at at 75 %
60 C at 100 %
se what happens
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old July 5, 2012, 05:28 PM
Sweet thanks, very nice, let me try this!
Originally Posted by ZZLEE View Post
multi 21
QPI 198
V cpu 1.34
pcie +0.5
Ram 1.60 V
Ram at 2:8
see what happens
fans at 100 %
then ajust to :
40 at at 75 %
60 C at 100 %
se what happens
Thank you as well sir, I am going to try this too!
Old July 5, 2012, 06:19 PM
Is this safe?
Base clock 160
Multiplier 25
CPU - everything off except HT and all cores
LLC - follow intel specs
V core 1.325
QPI/VTT 1.275 from 1.175
What do you think?
Old July 5, 2012, 06:25 PM
ZZLEE's Avatar
Looks good :)
Might take them reds off trade biat list as long as you want to keep this board.
wont find better clockers fore this board likley. Edit: Ram I mean
Edit : Wats your temps NB ? SB ? CPU ?
Old July 5, 2012, 06:39 PM
max i get is I believe 44, I ran linx a boot ago and max temps for cpu were 68 degrees and I am using Prolimatech Meghalems with 2 scythimg 1900rpm fans. Yes this ram is really sick. crazy timing lol
Old July 5, 2012, 06:45 PM
ZZLEE's Avatar
that 25 multi realy helps on the temps. looks good :)
Old July 5, 2012, 06:48 PM
ya, thank you for all your help!
Old July 5, 2012, 06:51 PM
ZZLEE's Avatar
NP EH...
Gigabyte X58A-UD3R misreading temps? Syn3rgetic Troubleshooting 8 December 28, 2010 06:41 PM
core i7 930 + gigabyte GA-X58A-UD3R Rev 2.0 imperatrix Troubleshooting 44 November 17, 2010 06:10 PM
Is that a good choice for Case & Power for a Gigabyte X58A-UD3R ? Godis New Builds 14 July 18, 2010 07:08 PM
[FS] Brand new Gigabyte GA-X58A-UD3R - $200 Zero82z Buy/Sell & Trade 3 July 10, 2010 03:06 PM
Gigabyte x58a-ud3r madmax2 CPU's and Motherboards 2 February 23, 2010 04:06 PM
