  #21 (permalink)
Old July 1, 2012, 12:34 PM
Prime 95 27.7 build 2 as of May about the 15/12 runs avx instruction set now methinks
even my 2500k runs tad warmer under this newer build.
But my son mentioned his 2011 chip gets warm with new Prime 95 on high o'clocks
Cambridge,ON
MSI Z77 M Power/Bios17.7
i5 3570k@4.5ghz
Mushkin #997007
Noctua NH-D14
EVGA GTX460
Seasonic X-660
Antec P280
Intel Speed Demon Equipped
using Prime 95 27.9
  #22 (permalink)
Old July 1, 2012, 11:14 PM
Originally Posted by Your_friendly_gamer View Post
Jj from Asus recommends max v core of 1.325 to 1.35v. If you are just gaming I would keep it at 1.30v and whatever oc you can get. After watching this video I am gonna get rid off prime95, and LinX, I used the a lot!
yeah, i saw the video
my vcore jumps between 1.352 and 1.36, close enough :P
http://www.heatware.com/eval.php?id=80890
  #23 (permalink)
Old July 2, 2012, 03:24 PM
I'm surprised at how high your voltages are guys, no wonder temps are highs. I'm running mine at 1.010v @ 4ghz, you would need about 1.075v for 4.4ghz and 1.175 for 4.6ghz. Did you guys really bother to tweak to the lowest stable voltage?
  #24 (permalink)
Old July 2, 2012, 07:21 PM
Your_friendly_gamer's Avatar
That is so high for your oc. Where is your LLC? lower it, and then try.
  #25 (permalink)
Old July 5, 2012, 09:54 AM
i found out it was kind of high because after 4.5ghz, it takes A LOT more voltage to stabilize my chip
i wanted 4.8ghz, but i'll stick with 4.5ghz for now.
i'm at 75% llc, 1.272vcore and its 100% stable, i'll tweak it later to get the voltage down a bit
and apparently even up at 1.36 my 4.6 wasn't stable, it could pass the aida64, but it crashes during games and intel burn test <- instantly lol
magnetic just has a golden chip.
at 1.175 i can only get up to 4.3
  #26 (permalink)
Old July 5, 2012, 06:02 PM
pop the heat spreader off and apply some good thermal paste, should bring down temps 10c. lol
[FS] 2 XSPC Razor 7970 full cover waterblocks. Syl66 Buy/Sell & Trade 12 September 18, 2012 08:36 PM
Motherboard for 3570k popeye111 New Builds 7 May 15, 2012 05:23 PM
Help choosing a MB for i5 3570K? Lucasrivers CPU's and Motherboards 2 April 30, 2012 03:18 PM
Super cheap, but not super crappy first WC build log donimo Case Mods, Worklog & Gallery 83 February 21, 2009 10:24 PM
