Old June 24, 2012, 09:45 AM
What program do you use to read temps. I read somewhere that a lot of the programs don't read ivy bridge chips correctly.
Old June 24, 2012, 05:22 PM
i used realtemp and ai suite, both had similar temps.
unlike the other guy, as soon as prime stops, my temperatures drop straight to 40
http://www.heatware.com/eval.php?id=80890
Old June 24, 2012, 06:27 PM
My 3570K is clocked at 4.2GHz and 1.2v. I use CM 212 EVO with Noctua NF-F12 PWM fan. My temps goes up to 65C running Prime95. IntelBurnTest can get it up to 75C.
Yeah I would try reseating the heatsink like the other guy said. What are your temps at stock speeds?
Old June 25, 2012, 08:13 PM
at stock speed its around 36-45 on idle
with just the stock 212 fan pulling
Old June 25, 2012, 08:23 PM
gingerbee's Avatar
well i can tell ya a fan just pulling is never a good one fan option you should have it blowing if ya only have one fan on it and i can tell ya a push pull does work pretty good on the 212
Old June 25, 2012, 08:51 PM
i did have a push pull on it, but i took out the fan because i'm running at stock atm and the other fan is really loud.
but even with push/pull my temps are still very high
Old June 25, 2012, 10:33 PM
gingerbee's Avatar
ya i jumped ship for a few reason, socket 2011. Temps were one of them i now have a 3820 that runs @5ghz @1.43vcore i just gotta get the water chiller i want and she going up to the land of hole crap overclocks lol mind you even at that low vcore she still climbs now into the high 70's which is too warm for me right now but she only on a h100, once she on custom water loop+ Hailea HC-500A 100V (1/2HP=790Watt cooling capacity) Waterchiller Products Model: HC-500A [HC-500A] : Performance-PCs.com, ... sleeve it and they will come
she will be loving me and the highest clocks i can get without going over 1.5vcore
Old July 1, 2012, 01:29 AM
alright so i switched 2 of my case fans to ap-15s and i got 2 more ap-15s push/pull on my hyper 212+
max. temps on aida64 is 80 running 4.6ghz at 1.36vcore.
i tried for 4.7ghz and went up to 1.4vcore and it wasn't stable
is it worth it to keep going? or should i stay with the 4.6?
  #19 (permalink)
Old July 1, 2012, 08:58 AM
I think the 4.6 is pretty good. You aren't going to notice any difference. You can keep trying if you are just trying to benchmark though.
I'm impressed. The heat doesn't seem to be quite as bad as people made it out to be when ivy was first released.
  #20 (permalink)
Old July 1, 2012, 10:38 AM
Your_friendly_gamer's Avatar
Jj from Asus recommends max v core of 1.325 to 1.35v. If you are just gaming I would keep it at 1.30v and whatever oc you can get. After watching this video I am gonna get rid off prime95, and LinX, I used the a lot!
[FS] 2 XSPC Razor 7970 full cover waterblocks. Syl66 Buy/Sell & Trade 12 September 18, 2012 08:36 PM
Motherboard for 3570k popeye111 New Builds 7 May 15, 2012 05:23 PM
Help choosing a MB for i5 3570K? Lucasrivers CPU's and Motherboards 2 April 30, 2012 03:18 PM
Super cheap, but not super crappy first WC build log donimo Case Mods, Worklog & Gallery 83 February 21, 2009 11:24 PM
