-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   Where to get Orthos for 4 cores? (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/547-where-get-orthos-4-cores.html)
francois methot March 11, 2007 09:05 AM
I found GO-Orthos Beta for 2 cores. I saw some posts that peoples was using Orthos for 4 cores; Where can I get it?
SKYMTL March 11, 2007 09:07 AM
Can't you run 2 instances of Orthos?
francois methot March 11, 2007 09:10 AM
Yes, but it shows using CPU 0 and CPU 1 on the second run. No mather how many windows that I open, it is always the same CPUs!
flclisgreat March 11, 2007 09:27 AM
try installing it twice, to 2 different folder's. name the second folder core3 or something. may work
francois methot March 11, 2007 09:29 AM
I attched a clip when I run two Orthos
enaberif March 11, 2007 09:40 AM
Run two instances then set the affinity of the 2nd program to use core 3 and 4
francois methot March 11, 2007 09:50 AM
...I can't see where to set the affinity.
I see that I can set the priority and sensors, but nothing about the affinity!!!
I have the GO-ORTHOS BETA 20060420
cdn_Madrach March 11, 2007 10:15 AM
Affinity is in the task manager under processes right click on process you want to set to affinity.
Supergrover March 11, 2007 10:20 AM
While I dont have a quad core it should work with different folders, just like running 2 instances of F@H.
Check Task Manager and see if your @ 100% usage.
enaberif March 11, 2007 10:25 AM
Toms hardware has a program that sets the affinity and remembers it but i forget the name.
