Old June 10, 2012, 04:32 PM
fireXtract's Avatar
Post Overclocking Phenom ii 970 Questions
I have AMD Phenom II X4 970 Black Edition Deneb 3.5GHz
I use ASUS Turbo-V EVO because i have the ASUS M4A88TD-V
Is it better to raise the CPU ratio on each core or change the CPU Frequency.
Also when is it appropriate to change the Voltages and what was the stock 970 black edition voltages?
Old June 10, 2012, 06:05 PM
Your_friendly_gamer's Avatar
Yea for those, do a combination of both. When I had AMD, I got a better performance by ocing both. ALso don't forget about NB frequency. With AMD they got 3 things going for, NB, Hypertransport and then the ratio.
Old June 11, 2012, 09:56 PM
fireXtract's Avatar
What is hypertransport and what would be a good balance to get 4.0Ghz?
Old June 12, 2012, 03:33 PM
Bond007's Avatar
Can OC it all as mentioned above if you want to play around with everything. If you are a beginner to OCing then just increasing the cpu multiplier (should be ratio in that program) gets you 95+% or the performance with less hassle.
Old June 19, 2012, 06:36 AM
fireXtract's Avatar
Thanks
Tags
frequency , overclock , phenom ii 970 black , ratio
Phenom II IMC & Ram Overclocking Guide Slappa Guides & How-to's 13 December 11, 2011 04:08 PM
overclocking my phenom II x3 720 ultraman7k Overclocking, Tweaking and Benchmarking 16 April 19, 2010 12:05 AM
Overclocking a Phenom II 940 AmuseMe Overclocking, Tweaking and Benchmarking 7 June 17, 2009 08:19 AM
Phenom II Overclocking geokilla Overclocking, Tweaking and Benchmarking 7 May 29, 2009 03:39 AM
Phenom II Overclocking Jonwall Overclocking, Tweaking and Benchmarking 16 February 8, 2009 08:00 PM
