  #21 (permalink)
Old March 11, 2007, 08:31 AM
sswilson's Avatar
3 beeps is supposed to be memory.
If the board cannot access memory, it's not going to be able to do a bios flash. Normally memory problems require a cmos reset, while processor OC problems will cause a board to return to default bios settings on its own.
Just to be sure.....
Did you do the cmos reset rather than recovery? (Power off, jumper off of pins 1+2, over to pins 2+3, wait 30 sec, back to pins 1+2).
Have you tried booting just one stick of memory in each of the different slots? (try this with each stick of mem just in case one of them is bad).
If you can easily get your hands on an old PCI vid card it wouldn't hurt to try. (I haven't personally seen this as a snag with a PCIe setup, but it used to be common with AGP that it would require a PCI vid card to reset the agp slot settings).
If all else fails you can try to do a long cmos reset. (Sometimes the caps on a mobo keep bios information alive for quite some time and the only way to clear it is to completely drain the system).
Unplug the power cord, press the power-on button to drain the caps, remove the battery, move the jumpers from 1+2 over to 2+3, and then leave it like that for 12-24 hours, return the jumpers to 1+2, re-install the battery & try to power it up.
If this doesn't work you're getting to the point where you're beating a dead horse. You're either going to have to get the board replaced, or get a replacement bios. (If you decide to go that route I can find you some links for bios replacements).
edit.... heh, I guess I took too long to type this one up. :)
  #22 (permalink)
Old March 11, 2007, 08:58 AM
I didn't try :(Power off, jumper off of pins 1+2, over to pins 2+3, wait 30 sec, back to pins 1+2)....but I will later on.
Now I am back on track with my spare mobo and I wont OC for now.
My main interrest in fast computer is RF circuit simulation...
Thanx again!
Intel Core 2 Quad QX6700 OC 3.6GHz
Mobo D975XBX2, 4GB DDR2 800 MHz Corsair TWIN X Dominator
4X 36GB Raptor in RAID 0 (on Intel controller with dual Boot Win32 Pro)
3X 360 GB Seagate No RAID (on Marvell controller for Apps, Paging and Back up)
EVGA GeForce 8800GTS Dual DVI- 2x Monitors 24'' 1920 x 1200
Water Cooling, Ultra X3 1000 Watts PWS.
ASUS Laptop G2S T7700 @ 2.4GHz
  #23 (permalink)
Old March 11, 2007, 09:12 AM
sswilson's Avatar
Thanx again!
I'd say it's a 95% chance or better that it will fix the problem.
Standard cmos reset is a normal requirement for bios OCing.
  #24 (permalink)
Old March 11, 2007, 10:16 AM
Supergrover's Avatar
Bingo
This should be the first step when something goes bad with a overclock. As I said in post #2
Extra bandwidth IS NOT worth the abuse these boards take when pushing like this. Some people will not agree, but it does NOT add up and does NOT help in real world applications. The ONLY place you see that little bit of bandwidth doing anything is synthetic benchmark scores.
I got to say this, I run 2 overclocks on my rigs
1 is 24/7 stable and is for everyday use a healthy overclock that I know will be rock solid (nothing worst than gaming and you crash because you 1-2 mhz to high)
#2-I run the highest possable overclock that will run benchies 3Dmark/superpi/ect this is not a "stable" overclock but will yeild the highest score.
So yes there is a reason to run higher FSB, if you are shooting for that elusive score then yes I would and do.
R.I.P.
BD remote trouble on my PS3 ebdoradz Gaming 0 January 6, 2008 07:46 PM
PS3 wi-fi trouble ebdoradz Networking 8 December 8, 2007 06:12 PM
Pushing the PC gaming boundaries magictorch Press Releases & Tech News 0 November 16, 2007 07:45 AM
Trouble with fan controller. chibi_man Troubleshooting 2 September 24, 2007 06:49 PM
Trouble On The Horizon mo' power Off Topic 0 August 22, 2007 06:51 PM
