Old March 10, 2007, 10:22 AM
stability loss? ANYTHING over stock is not perfectly stable, or the chip maker would have bined it to that. all be it user's wouldn't/can't test for stability as good as the company, and we don't need it to be that stable. true, ram speed has very little effect on performance. but when you add it all up, the ~5% boost from bandwidth, the ~3-5% boosts from higher ram speed's, the ~xx% boost from overclocking the cpu, it all adds up, and pretty quick to.
Old March 10, 2007, 10:41 AM
b1lk1's Avatar
But it all adds up to higher benchmark scores with almost no real world gains. That is what I am getting at. If you want to highest 3D Mark score, then you need all the bandwidth you can find. But for real world 24/7 use, slightly higher bandwidth is meaningless when your PC is BSODing all the time.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Old March 10, 2007, 11:14 AM
...I tried to recover the bios by removing the bios jumper, loaded the disk and the system beep again.
Intel Core 2 Quad QX6700 OC 3.6GHz
Mobo D975XBX2, 4GB DDR2 800 MHz Corsair TWIN X Dominator
4X 36GB Raptor in RAID 0 (on Intel controller with dual Boot Win32 Pro)
3X 360 GB Seagate No RAID (on Marvell controller for Apps, Paging and Back up)
EVGA GeForce 8800GTS Dual DVI- 2x Monitors 24'' 1920 x 1200
Water Cooling, Ultra X3 1000 Watts PWS.
ASUS Laptop G2S T7700 @ 2.4GHz
Old March 10, 2007, 01:17 PM
sswilson's Avatar
Ok what's the beep code?
Time to start removing everything but the bare necessities to see if you can get it to post. (This is where I normally pull out my trusty pci vid card).
Double check to ensure that all of your power and fan connectors are properly made, and pull all but one of your mem sticks. Remove any extra pci cards you are running, and drop back to one ide hard drive (we're not trying to boot into OS at this time, just trying to get you into bios).
Old March 11, 2007, 06:17 AM
Unhappy
OK... did that but I used the PCI express vid card, I don't have pci one anymore. Same 3 long beeps!
Old March 11, 2007, 06:20 AM
...should I go borrow a pci vid card et try it again?
Old March 11, 2007, 07:23 AM
...during the recovery BIOS with the bootable disk (jumper removed), I am suppose to heard 2 beeps....indicating successfull BIOS recovery, I never heard these 2 beeps.
Old March 11, 2007, 08:15 AM
b1lk1's Avatar
Your options are limited considering you don't seem to have other parts available to test with. I'd have to say something is dead, but it is a matter of figuring out what. I'd start with the mobo. What voltages were you pushing when this happened? Quad core CPU's also seem to be punishing boards when they are overclocked.
Extra bandwidth IS NOT worth the abuse these boards take when pushing like this. Some people will not agree, but it does NOT add up and does NOT help in real world applications. The ONLY place you see that little bit of bandwidth doing anything is synthetic benchmark scores.
RMA the board and hope for the best with regards to your other components. Unless of course you have another CPU to test with, that is about the only thing I can think of that you can do.
  #19 (permalink)
Old March 11, 2007, 08:27 AM
I change the motherboard and everything is fine now. I had a spare mobo just in case...
...learn my lesson!
I will try to find out the problem later!
Thank you all!
  #20 (permalink)
Old March 11, 2007, 08:29 AM
about RMA the board....will they take it even if I OC it?
BD remote trouble on my PS3 ebdoradz Gaming 0 January 6, 2008 07:46 PM
PS3 wi-fi trouble ebdoradz Networking 8 December 8, 2007 06:12 PM
Pushing the PC gaming boundaries magictorch Press Releases & Tech News 0 November 16, 2007 07:45 AM
Trouble with fan controller. chibi_man Troubleshooting 2 September 24, 2007 06:49 PM
Trouble On The Horizon mo' power Off Topic 0 August 22, 2007 06:51 PM
