-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   Help me tweak my OC! (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/54422-help-me-tweak-my-oc.html)
Pabz0r545 June 3, 2012 12:29 PM
Hi all. I have achieved 4.8ghz @ 1.42v on my i5 2500k. Not sure if this is good as I'm quite new to this. It's only my 3rd time overclocking. I would like to reach 5ghz or even higher if the chip will allow so. Maybe 4.8 is it's max? Not sure. I am wondering what I can do to try getting it higher. I upped the voltage and multiplier but was unable to boot into windows at 5.0ghz. If I can't get higher maybe I can just reduce the voltage for lower temps. Not sure but I need help.
Specs as far as OC goes are :
i5 2500k
MSI Z77A-GD65
and a 360mm HWlabs rad with AP-15's on it.
here are some pics.
Here is the OC genie section. changed multiplier, disabled xmp(?), manually set voltage, disabled C state(what is this like speedstep?), and I upped the long and short duration power limit.
http://i1198.photobucket.com/albums/...r/msBS0001.jpg
Here are the regular bios settings outside of the OC genie profile. Here I disabled spread spectrum, disabled EIST. I wasn't sure if I should keep PLL Auto or straight up enable it so I left it auto. Couple things I am wondering here is what is the Vdroop setting and what is Digital compensation level?
http://i1198.photobucket.com/albums/...r/msBS0002.jpg
http://i1198.photobucket.com/albums/...r/msBS0003.jpg
Here is the CPU features menu. I disabled C1E support. I seem to recall that overspeed protection should be disabled? hrmm I thought i disabled C state.
http://i1198.photobucket.com/albums/...r/msBS0004.jpg
And here is my temps cpu -z. I would like to call this stable. I know it was only 3.5 hours and lots of folks do 12-24 but in reality it would be hard for me to get more then 6 hours. Plus my gaming will never bring this rig to 100%. I'm thinking a reseat and some ic7 diamond would do me some justice on temps. It was the worst seat I have done in my life trying to mount that xspc raystorm by myself with 1 hand on the backplate.
http://i1198.photobucket.com/albums/...PabzOr/p95.jpg
http://i1198.photobucket.com/albums/...r/tempcpuz.jpg
I had to crop those because when I straight up load the desktop screenshot to photobucket it comes out like this and you can't read any of it.
http://i1198.photobucket.com/albums/...8ghzstable.jpg
So I have a few main questions. I did the overclock in my OC Genie profile. Is this n00b? I did this because I was using the stock OC genie settings before and I just changed a few things in there since it seemed easier. Ended up having to change other settings elsewhere though :P.
Should I be doing it straight up bios settings as opposed to in the OC genie section of the bios?
What changes could I make to push it to 5.0 or higher? Yeah yeah blah blah I know it's not much difference but dished out the $$ on the parts with capabilites so I would like to try. :biggrin:
Your_friendly_gamer June 3, 2012 02:08 PM
Under the cpu features, disable everything. Bump up your DRam voltage to 1.525. Not all cpu's can achieve 5.0 at 1.45 or under for sandy bridges. Bump up your v core to 1.5 and change the multi to 50 and see what happens? As long as your max temps on Prime 95 are below 80, you are doing alright, but I wouldnt pump that much voltage for everyday use. Maybe just for benches and stuff.
