Old June 3, 2012, 12:01 PM
Chasingu's Avatar
Default Best Settings
I am going to be getting an i5 2500k soon and the motherboard is a GIGABYTE GA-Z68X-UD3H-B3. I know not all chips are the same and don't always overclock the same, but I would really like to push this to 4.2GHz. My cooler is a Notcua NH-D14. It would be awesome to have some settings to put in to get this overclock, but I don't know where to even start.
Old June 3, 2012, 12:34 PM
4.2 might be able to be achieved with just a simple multiplier adjustment. I know my first board ASRock P67 Extreme4 Gen3 was capable of this.
Old June 3, 2012, 01:57 PM
supaflyx3's Avatar
If your mobo has an auto OC button, that's about where it'd put you if you were to use it.
what settings to run vantage at? BrianHanna Overclocking, Tweaking and Benchmarking 0 October 27, 2009 12:28 PM
OC Settings jumran Overclocking, Tweaking and Benchmarking 1 September 30, 2009 05:30 PM
Help with Biostar P45 settings! Silvgearx Overclocking, Tweaking and Benchmarking 0 May 12, 2009 01:36 AM
Old and New Settings WolfBane Overclocking, Tweaking and Benchmarking 51 February 28, 2009 08:23 PM
Ram settings JupiterTrooper RAM 5 September 16, 2008 05:36 PM
