Old March 9, 2007, 10:09 PM
Default Dimm Slots
I'm gonna assume the answer here is yes, but can you damage your dimm slots from overclocking?
I pushed my ram from 400mhz to 430mhz and my cpu from 3.0ghz to 3.5ghz and it seems no matter how good the memory is that I get memory errors on error free ram.
I am planning on getting a new system, but I was wondering if the life of this board was coming to a end.
Old March 10, 2007, 04:12 AM
Babrbarossa's Avatar
I would guess that unless you were overvolting as well, then it was nothing you did to burn out the dimm slots
psst, wanna see my binder?
Old March 10, 2007, 11:27 AM
Deathspawner's Avatar
As Babrbarossa said, overvoltage could do it, but not extra frequency. Especially 400 > 430... that's a seriously minor difference.
Errors could be caused from dust though. I'd take the modules out and wipe the contacts with a fine, clean cloth, or your clean fingers. Use canned air to spray out the DIMM slots. Then see if the problem continues.
Techgage.com | Editor in Chief
Intel Core 2 Quad Q9450 @ 3.20GHz, ASUS P5K Premium WiFi-AP, OCZ 8GB PC2-6400, EVGA GTX 285 1024MB
Seagate 500GB, 750GB & 1TB, Pioneer 22x ODD, Corsair 1000HX, Thermalright Ultra-120, CM Storm Sniper
Dell 2408WFP 24", ASUS Xonar Essence STX, Ultrasone PRO 750, Gentoo Linux (KDE 4.4, 2.6.32 Kernel)
"Take care to get what you like, or you will be forced to like what you get!" - H.P. Baxxter
Profiles: Last.fm | Xbox Live | Steam
Old March 10, 2007, 12:23 PM
sswilson's Avatar
If it's an AMD proc it's possible that overclocking could damage the on-chip memory controller, but while I've come across a few folks who've lost their OC ability over time, I can't remember any case of them not being able to at least return to stock speeds.
I'd bet that one of your advanced mem settings got foobarred.
