Old April 6, 2008, 05:13 AM
Unklmo's Avatar
Default Speedfan or CoreTemp ?
pretty sure this question has already been discussed, but i'm wondering which one of these 2 app's i should trust to be more accurate with my temp readings.
or should i just split the difference between the two?
Old April 6, 2008, 07:00 AM
Trust HW Monitor
Old April 12, 2008, 11:06 AM
I posted something similar. From what Ive read is that for 45's Real Temp is the most accurate (according to Extreme OC and Anandtech) and SpeedFan if you can set is properly is 2nd. You have a 65 so I guess SpeedFan (properly adjusted shown be it). That being said im using HW monitor, I just like all the different readings. BUT the most important is how far you are from your Tjmax, which is shown is RealTemp not to sure about Core Temp
Old April 12, 2008, 12:52 PM
3.0charlie's Avatar
I used Coretemp with my Quads - and by your s/s, your temps as shown by Coretemp are fine for your cooler. And Coretemp can be configured for Tjunction Delta.
Hydro-Quebec is salivating...
Old April 12, 2008, 12:53 PM
Unklmo's Avatar
ty guys
