Old January 22, 2013, 05:11 AM
turtletrax's Avatar
Hey, awesome!
I usually left the chip upside down in enough to cover the adhesive for about 24 hours, and never felt like more time would have made it easier. I also used the Gillette double sided razor cut in half for safety reasons.
Be sure to let us know how it works!
In progress: Other hobbies.
Old January 22, 2013, 08:50 PM
CroSsFiRe2009's Avatar
Well, it's been 20 hours. Tried to delid at around the 12hour mark using a box cutter blade but had no luck. Need to wait for my DE blades to arrive. I think mounting my D14 compressed it a bit too much
Old January 22, 2013, 11:14 PM
turtletrax's Avatar
I think box cutter blade is too thick and not quite sharp enough. Should mave much more luck with the think blades.
Old January 23, 2013, 11:25 AM
Yep, you were right. Feather DE blades went through it like butter but one corner refused to let go so it took about 40min to remove it. There was a ton of suction which made getting the ihs off really hard. Soaking the ihs in solvo at the moment so I don't know if it works yet
Old January 23, 2013, 11:34 AM
geokilla's Avatar
Why would you delid it?
And that looks so dangerous... A drop on the pins = bye bye CPU?
Old January 23, 2013, 12:38 PM
Master_Shake_'s Avatar
they de-lid to lower temperatures by changing the stock paste that intel decided to use on the ivy cpus. between the core and the ihs also intel cpus do not have pins...
/nosureifstupid.jpg
Old January 23, 2013, 01:42 PM
turtletrax's Avatar
I did have an issue with suction a couple times. I ended up just letting it dry after cutting for a couple hours.
I bet all is good
A drop of what on the pins? You could soak the whole proc in this stuff and no damage, only reason I never covered more of the proc is not to waste Solvoplast. It will not harm the proc, and it is a LGA proc, so no pins.
Old January 23, 2013, 03:04 PM
lowfat's Avatar
Should I be able to find this stuff locally?
  #19 (permalink)
Old January 23, 2013, 03:53 PM
turtletrax's Avatar
If you have a Safeway with a drug store in it you might get it there. Where I got my first bottle way back when. Still rocking the same bottle :)
  #20 (permalink)
Old January 23, 2013, 03:56 PM
lowfat's Avatar
BRB. Off to Safeway.
EDIT: Looks like your Safeway is cooler than my Safeway.
HELP!! Poison Ivy Trojan removal! BobbyLou Troubleshooting 24 February 27, 2010 07:38 PM
Driver removal? encorp O/S's, Drivers & General Software 2 February 16, 2010 03:28 PM
Contemplating a wood PC S_G New Builds 34 October 22, 2008 05:07 AM
Plastic cover removal on GTX magictorch Video Cards 6 December 29, 2007 02:33 PM
