Old April 25, 2012, 03:58 AM
Trial Member
Default Temperature variations in FX-8150
I'm doing stability testing at 4.0 GHz until the blade masters and leaf-blower case fans arrive (after which, I'll try to get to 4.4), and I've noticed that the temperature oscillates between 18 and 36 degC while running prime95 in an 8-thread configuration. Is this a normal effect of the AM3+ rapid Vcore switching? CPU is AMD FX-8150, motherboard is Asus M5A88-M and CPU cooler is Cooler Master Hyper 212+, in a push configuration.
Cut the 8150 in half? Pedwar CPU's and Motherboards 2 February 19, 2012 07:38 PM
fx 8150 weird cpuz lol gingerbee Overclocking, Tweaking and Benchmarking 7 December 29, 2011 06:03 AM
teasers FX-8150 oc'ing terrybear Press Releases & Tech News 9 September 15, 2011 04:47 PM
Temperature question ( which temperature do I go by? Shadowmeph Overclocking, Tweaking and Benchmarking 3 August 19, 2011 01:00 PM
