Old April 23, 2012, 08:21 PM
Trial Member
Default X4 955 OC @3.6 temp questions
Hey guys. New to this forum. I have a couple of questions regarding my idle and load temperatures as well as voltages. I OC'd my cpu to 3.6ghz with 1.344v running an m4a89gtd pro motherboard. Idle temps are 33c and max loads on prime95 for 30 minutes were 49c. I play sc2 and mafia2 and temps on that are 40-42c. Does all of this sound normal with my specs. Thanks
AMD Phenom II x4 955 BE @ 3.6Ghz
Asus M4A89GTD PRO
Nvidia GTX 560 ti
8GB RAM
Antec Kuhler H20 620
Corsair 700W
Windows 7-64 bit
Old May 10, 2012, 07:24 PM
yes, these temps are awesome. the safe temp for phenoms are about 65 degrees. seeing as you're far from this, you should be fine :)
Core temp VS CPU temp cul8erppl Overclocking, Tweaking and Benchmarking 8 January 5, 2011 02:10 PM
Real Temp or Core Temp or Ai Suite Jhayman CPU's and Motherboards 11 November 19, 2009 11:11 AM
CPU temp vs Core temp phil3_66666 Air Cooling 4 July 31, 2009 09:39 PM
Real Temp or Core Temp ?? FrankyG Overclocking, Tweaking and Benchmarking 11 September 29, 2008 11:24 PM
CPU temp or Core temp? E6420 NOOB Delavan CPU's and Motherboards 18 May 28, 2007 05:07 AM
