Old April 19, 2012, 10:54 AM
Painbringer71's Avatar
Default Overclock reset question
So I really did not touch much in bios just changed it to Manual and turned on the power to Performance. Save and exit. I then used Turbo V and what I thought all I did was change the multiplier from the software program to 15.5 My GPU went to 3.888. One click and its 3.888? It stays at this setting now (defaulted). Well I would like to set it back to stock levels. Any ideas ? What alarms me is I see screen shots of 15.5 multiplier at only 3.111 It is stable all temps under 40 but the power sensor to the chip is in the 50ís under load. I would like to set it back to stock. Can anyone let me know what to do?
Sabre tooth and the 8120 FX CPU stock is 3.1 (not sure what the mulitplier was out of the box i thought it was 15 but as my system is running now I have to go to 12 or below to get to a 3.1 state.)
Old April 19, 2012, 11:53 AM
dandelioneater's Avatar
turn off the pc and press the clear cmos button?
Memory overclock question. H-A-R-M Troubleshooting 2 November 14, 2011 10:05 PM
UL50VT Reset CMOS CroSsFiRe2009 Mobile Computing 3 November 19, 2010 03:23 PM
GTX 460 vs GTX280 and overclock question THS Video Cards 1 July 24, 2010 11:24 AM
Noob Overclock Question Phaddie Overclocking, Tweaking and Benchmarking 4 November 5, 2008 12:02 AM
Have to reset LAN Adaptor always-Help Malam Networking 2 May 25, 2008 08:03 AM
