Old April 14, 2012, 02:40 PM
Default Currently ocing 970
Hi guys from all the help everyone has given me on this forum i finally man'd up and attempting an overclock. Running at 3.9 ghz 1.35 vcore for about 10 minutes on prime 95. So far so good i plan on getting atleast 4.2 ghz. Im going to run this for an hour ( is that long enough) and see what happens. How quick would an error occur bythe way?
30 minutes in ive decided that it was ok but 1.35 v seemed to much based on such high temperatures 80 degrees c whew thats hot (tj max 101c) i went to bios and downed the voltage to 1.335. Running prime 95 again and hoping for better than last time. I also increased the core speed to 4ghz no sudden
Problems yet. Having a locked processor can i change the multiplier to 25 instead of 24? I saw a 970 with a multiplier of 25 in an overclocking review.
Ok i believe my overclock is succesful at 4.2 ghz. I anwsered pretty much all the questions I had but I now see that overclocking is really quite simple. I bumped it back up to 1.35 V and it seems to be solid. I know that there is more to learn about overclocking and in the future when I add some more fans and better my airflow I will try for a higher overclock but 4.2 ghz seems fine to me and ive notice a significant performance increase. It feels so much faster than before. Again I have to thank everyone on this forum for anwsering all my questions I had.
Old April 15, 2012, 03:29 AM
You're pretty much done with you're overclocking. My 970 can do 4200 (200*21) at 1,360 vcore without breaking the 60c barrier (under water), next step up is 4410 (210*21) at 1,424v and the 70-75 zone. Not really worth the heat and noise.
Now you've found the sweet spot for your cpu, time to tweak your memory. I can run 1830, 2000 and 2210 mhz and still get 4200 cpu speed. My cpu just doesn't work well with anything else than 19x, 21x and 23x. All depends on your IMC. Just up the mhz and memtest untill it fails, back down a little, then continue with lowering timings till it throws errors.
And don't forget to run your uncore as high as possible. Once you're running at high memory speed (1600+), each time you up the multiplier, it nets you a good increase in bandwith. Not really something you'll feel when browsing, but folding ppd increase linearly, so i would think that at least transcoding and (maybe) gaming will benefit from it.
And try to stay away from the itch to get better cooling...
Old April 15, 2012, 04:52 AM
its not so much as replacing the cooling its just adding cooling. Im underwater already and i reach 75c max on prime95 running for 2 hours, After that it pretty much stays at that temp. I think part of it might be is that im pulling hot air from the inside over the rad and out so i just need to turn the fans around. Im also adding another 200mm fan on the top so ill have 2 200's on the top. Im replacing all the fans in my case actually for more colorful better fans. I guess that would be better cooling but its about 75$ to do so ill do it. Not to mention one of the fans on the rad is broken. It still works without problems but am going to replace it also.
I forogt about increasing the ram speed. I am just now going to bed after a long gaming session and the overclock has held without any errors.
Old April 25, 2012, 06:03 AM
My 970 is a dog too. 4000mhz comes at 1.35, 4.1 @ 1.4, 4.2 @ 1.46, and 4.3 at 1.58...
As for heat.. Well mine went into protect at 107c.. Its been in the 90s many times, so they are pretty tough!
I just wish I had a nice one :(
Intel Xeon x5690 E.S.@ 4008Mhz, 1.25v
Asus Rampage III Formula @ 200/3609/3609
3x2GB STT Chrome @ 802Mhz 6-6-6-20 1T, 1.65v
Asus GTX 580 Matrix @ 900/1000
Intel 520/WD Black
Auzentech Prelude
Thermaltake SP850M
Fractal Design Define R4
Old April 25, 2012, 10:58 AM
Fudd Rucker's Avatar
My 970 is running 4.4 under water with temps running @ 70s. Your best bet is to get a triple rad and 3 x 120mmx38mm 3000rpm fans in a pull config set to medium.
I couldnt think of something snarky or interesting to put here this time around.
Old April 25, 2012, 11:13 AM
Adzsask's Avatar
^ 2nd this, even a quad 130watt CPU is hard to keep under wraps, I run an RX360 RASA kit on my 950, 4.3 1.42v full load temps are 60C, 38mm fans are a bit much noise/price wise though 3 gentle typhoon 1850RPM is what I use and they work great. Hope my OC guide helped you get started into overclocking, it is super addictive!
Old April 26, 2012, 06:16 PM
I agree, my 970 runs cooler then my old 965xe es did. I am a member at another forum, and a guy I know there, who lives in my city has a 970 that he got from the retail edge program.. His 970 is running at 4.4 with 1.2875 on its stock cooler, or maybe it was 4.2 with 1.28.. Either way its disgusting
s775 was the last time I had a good chip
Intel 520/WD Black
Auzentech Prelude
Thermaltake SP850M
Old April 26, 2012, 06:47 PM
ZZLEE's Avatar
3.8 on C0/C1 920 rihgt now
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old May 5, 2012, 12:10 PM
elmorejohn46's Avatar
I looked at it wrong and thought you were talking about the i7-920 .I bought around 3 and half years ago It was a DO ,but I ran it at 4.2gigs at 1.435v frome day one and never had any problems It idle 37c to 39c and with prime 95 it did 80c to 85c,but in normal gameing I hardly ever seen it go past 72c.
Intel-i7-3820+Corsair H-100+Gigabyte X79-UD5+16g G.Skill 1666DDR3+256g Crucial-SSD+1-3TB Seagate+2-1TB-Samsung+1-640g- WesternDigtal+SLI-ASUS DIRECT CU II GTX-670+LG-12x Blurner+Logtech G9x-mouse+G-110-keyboard+Driving Force GT Wheel+Pioneer VSX-1020K+Polk Audio Speakers+LG-50"Plasma PM6700+Antec-P280+XFX 850w PRO Semi-Modular
X58 OCing yycraven Overclocking, Tweaking and Benchmarking 12 July 22, 2011 10:43 PM
OCing Help Finkswitch Overclocking, Tweaking and Benchmarking 16 February 4, 2011 05:33 AM
My first run at OCing the i7 930 Jackquelegs Overclocking, Tweaking and Benchmarking 14 September 6, 2010 06:41 PM
Not New To OCing, But New To OCing A i7 Uberg33k Overclocking, Tweaking and Benchmarking 9 March 23, 2010 01:00 PM
OCing help please SpateD Overclocking, Tweaking and Benchmarking 4 January 23, 2008 09:38 AM
