Old March 27, 2008, 06:06 AM
Default Q about real temp by intel and CPUID monitor
Just put together a box last week and ive been playing around for an everyday usage OC thats not hot (also trying to find a good OC for when I need it). I came upon Real Temp by Intel today and compared it to CPUid monitor. Core temps seem to be around 10C cooler with the program from Intel. Whats your experience and do you have more info on who is more accurate. I included a screen shot.
Cheers Canucks
specs
CPU Qx9650 running @ 3.6Ghz with 1.22 volts
memory 3 gigs of OCZ ddr3-12800 platinum enhanced bandwidth @ 1600 ( I can only get 3 sticks going)
mobo P5E3 deluxe
Old March 27, 2008, 06:07 AM
attachement
Old March 27, 2008, 08:15 AM
SugarJ's Avatar
The thing about core temperature sensors is that they do not report actual temperatures, but the difference in temp from max (TjMax - short for Thermal Junction Maximum). The problem arises in that Intel does not publish TjMax for their chips. HWmonitor probably uses a TjMax of 105 for your chip, while Intel's shows a TjMax of 95.
So when the temp sensors report back a difference of say 65 from TjMax, HWmonitor says the temp is 40 while the Realtemp prog reports 30.
Which one is correct? If the RealTemp program is the most current version (say released after the 45nm chips announced) it probably is accurate. After all, Intel program, Intel chip, right?
This is the first time I've heard of this program, going to try to find it now.
Old March 27, 2008, 10:03 AM
yeah its a new program I found it at Real Temp - New temp program for Intel Core processors - XtremeSystems Forums
thats what i figured intel + intel = should be right
Old March 27, 2008, 11:43 AM
stoanee's Avatar
Wow....Real Temp is reading approx. 10C lower! Is this to be trusted?
Attachment 1824
heatware
Old March 27, 2008, 11:58 AM
Maybe test out CoreTemp and SpeedFan along with it to see what other mainstream programs are coming up with?
Old March 27, 2008, 12:09 PM
Cptn Vortex's Avatar
Realtemp is accurate for the new 45nm chips, not sure what it will report with the older 65nm's though.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old March 27, 2008, 12:40 PM
stoanee's Avatar
Attachment 1825
This is what is going on with mine.
heatware
Old March 29, 2008, 09:51 AM
SugarJ's Avatar
Hmm. Did some more digging. This is NOT an program released by Intel. This is based on someone taping a temp probe to a chip and trying to work back from there.
I'm very skeptical of this approach. The sensors measure the CORE temperature, not the heat spreader temp.
While we are all fascinated with the absolute temperature numbers (My cpu runs at 48 degrees under load), maybe we should be more interested with the delta TJ Max or headroom. ( i.e. at load, my cpu runs 17 degrees cooler than TJ Max)
All these programs (Coretemp, Everest, HWMonitor, RealTemp) work on assumed TJ Max numbers and are best guess approximations by the programmers
In short, believe the higher number for now
