Originally Posted by hansonyip i5 2500k (4.3 Ghz)
Gigabyte z68a mobo
H50 set up as push pull config
Kingston 2 x 4Gb ram (1600)
ATI 5750
OCZ 550 Watt
My idle temperatures are usualy 30-33. When i ran prime95 it suddenly jumped from 30 to 90 within seconds. After i stopped the test the temperatures instantly went back to 30. (Also it makes a humming noise ONLY when prime95 is running)
So my question is what is causing the humming sound and would i need a bigger PSU or new cooler?
Thanks for looking. |
You could have Coil whine comming from either the board or PSU that is only evident when its loaded.
Is your PSU a New OCZ model or one of their older ones?
As for Temps, My H50 doesn't do that and I have a much Hotter running CPU.
I don't see 58 LOaded max.
Clean the paste off and re-seat it.
-ST
