Old March 26, 2012, 05:35 PM
gingerbee's Avatar
ya peaks at 1.52 is fine but running it there constant i would not tell ya that is was ok just to high for my liking but good clocks i got there too and it took the same vcore so it's pretty normal
I am thinking about rocking it at 1.5 for awhile till i can get a 3770k
Old March 27, 2012, 05:22 PM
Your_friendly_gamer's Avatar
Default 5.0 at 1.42
Did some more tweaking and settled at 5.0ghz @1.42v with LLC disabled. Not too bad, I am very impressed. My max temps never went above 65 degrees.
CPU-Z Validator 3.1
Old March 27, 2012, 06:49 PM
ZZLEE's Avatar
Don't play to hard and brake your toys :)
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
i7 860 voltages Nevakonaza Overclocking, Tweaking and Benchmarking 4 February 3, 2013 09:11 AM
i7 970 voltages Fudd Rucker Overclocking, Tweaking and Benchmarking 2 January 25, 2011 10:02 AM
Safe folding@home 24/7 voltages for i7 chrisk Overclocking, Tweaking and Benchmarking 17 January 2, 2011 10:15 AM
Safe Voltages for Core i3 540? Yamcha Overclocking, Tweaking and Benchmarking 7 December 17, 2010 04:40 PM
Overclocking i7 920 D0 voltages G777 Overclocking, Tweaking and Benchmarking 13 April 14, 2010 09:35 PM
