<~----> overclocking the e2140 - Hardware Canucks
Old March 23, 2008, 08:37 PM
cmac79's Avatar
Default overclocking the e2140
im sure its been done here but i couldn't seem to find it..i've found loads of info of ppl doin it and what they're overclocking to but nothing on acually how to do it. i've tried to get into the bios on a reboot but hp blocks it sometimes and of course i got the one that is. i was told to try systools but my motherboard is unreconized. im not lookin to get it up to 3.0 like lots are sayin u can, im happy with 2.0 to 2.5. my motherboard manufacturer is ASUSTeK Computer INC. and the model is Lancaster8 1.04. sorry if this has been done here before,i just couldn't find it lol. plz help i'd like to get a lil more outta this puppy cause i don't have the cash to go better right now lol. just let me know if u need a lil more info. thanx
Old March 23, 2008, 09:02 PM
BALISTX's Avatar
Welcome to the forums and if you are running a HP machine more than likely all those overclocking features are disabled in the BIOS. What model of HP computer do you have? I use to have a Pavilon a420n and all the overclocking features were locked. HP gets Asus as well as other motherboard manufacturers to manufacturer the boards for them, they are usually based off of existing boards. For instance the board in mine was Asus A7V8X-LA which was similar to the Asus A7V8X-MX. I tried flashing the BIOS to a BIOS for the A7V8X-MX but the BIOS wouldn't work.
How large is the HP tower you have. If you can you afford it you might be able to put a Gigabyte GA-P35-DS3L in the case. The board is around $90 and is a great overclocker. But chances are your case will only fit a mATX board in there.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old March 23, 2008, 09:14 PM
BALISTX's Avatar
I found these boards that might be your price range.
Gigabyte GA-P31-S3G ATX LGA775 P31 Express 1333FSB 1PCI-E16 3PCI SATA2 Sound GBLAN Motherboard - $70.31
Gigabyte GA-G33M-S2L mATX LGA775 G33 DDR2 800 1PCI-E16 2PCI SATA2 Video Sound GBLAN Motherboard - $101.92
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old March 24, 2008, 10:06 AM
cmac79's Avatar
thanx im sure i'll get good use of the forums here,found a few really useful things here already. I got a compaq Presario SR5310F acually. an at the moment i have absolutly no money to upgrade anything lol moneys a lil tight right now thats why i was hopin i could oc this one a lil
Old March 24, 2008, 10:19 AM
sswilson's Avatar
Unfortunately, the chances of overclocking one of the brand name box computers are pretty slim. Bios OC is out, I've even tried software OC on a couple of HPs, and consider myself lucky that I was able to reload the OS. :)
A word of caution on the bios as well...... You may find that the motherboard is a branded model motherboard (like ASUS or MSI), but should resist the urge to try to flash a different bios onto it unless you know for sure that it's going to work. HP, Compaq, Acer, etc..... use branded motherboards which often have the same model#s of retail boards, but don't follow the same spec, so flashing with a different bios will turn your tower into a relatively expensive paper weight.
Old March 25, 2008, 08:13 AM
cmac79's Avatar
so i guess till i can get another motherboard im shit outta luck huh lol. thanx for u help guys much apreciated
Old March 25, 2008, 09:48 AM
BALISTX's Avatar
Pretty much you are SOL sorry. Is your current mobo in the case an mATX
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
