Old March 6, 2012, 12:35 PM
Default Q6600 OC help
Specs: Q6600 @ 3.2 Ghz, P5K-e wifi, 8 gb of ram, HD 5750, OCZ 550W Psu,
I managed to get a ratio of 1:1 with a frequency of 400 Mhz, but I'm using 2 different types of ram.
OCZ DDR2 PC2-8500 /1066 MHz 2x2Gb and Kingston HyperX 4GB 2X2Gb DDR2-1066
I did 8 x 400 = 3.2 Ghz and made the ram run at 800 Mhz to get 1:1 ratio.
But when i changed the ram to run at 1066 Mhz i get 4:3 ratio, but faster speeds.
So my question is should i leave it at 1066 Mhz or change it back to 800Mhz for more stability.
Also just wondering if this build can run a Gigabyte 6850 to full potential, I plan on running eyefinity.
Thanks for the help.
Old March 6, 2012, 01:00 PM
Babrbarossa's Avatar
Hi - So if I understand correctly, you're OC using the higher freq and 4:3 is still about 3.2, right? So are you saying the memory is unstable at this setting? If so, then yes, go 800, otherwise keep it there.
the q600 won't limit that GPU in most applications.
psst, wanna see my binder?
Old March 6, 2012, 06:32 PM
Thanks Babrbarossa that answered my question.
[WTB] Q6600 MrFoxx Buy/Sell & Trade 3 May 13, 2009 07:07 AM
[WTB] Q6600 Phobia Buy/Sell & Trade 0 February 12, 2009 10:19 AM
q6600 anything better? angy CPU's and Motherboards 5 November 2, 2008 04:56 PM
Wtb: Q6600 G0 m4xn00b Buy/Sell & Trade 0 February 29, 2008 02:41 AM
Oem Q6600 Brando737 CPU's and Motherboards 2 December 16, 2007 12:22 PM
