Old February 28, 2012, 02:58 PM
Supergrover's Avatar
I have the same kit, 4x4, with 4 sticks I need voltage of 1.55v for stock timings.
As Sam said though you should have plenty of headroom just going to need some more voltage.
R.I.P.
Old February 28, 2012, 04:18 PM
yes the new elpida chips need more juice
but they are nice overclockers
some people gettin 2200mhz++++ 1.65-1.7v
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old February 28, 2012, 07:26 PM
r0k0's Avatar
well it runs good atm at 9-9-9-27 @ 1600mhz @ 1.5V, zsamz i will try it later :)
Main Rig
Intel Core i5 2500K - 5.0
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
AMD Radeon HD 6990 4GB 880 / 1300
Crosair 600T White / Enermax Revolution 920W
A-DATA 120GB SATA3 SSD / Seagates 1TB Spare SATA3
Canadian Eh ?
Apacer Announces ARES DDR3-2133 MHz Dual Channel Memory Kits for Overclocking Sam_Reynolds Press Releases & Tech News 6 July 3, 2011 10:35 AM
Patriot Memory Announces New AMD Black Edition Ready G2 Series Memory Kits Sam_Reynolds Press Releases & Tech News 0 June 14, 2011 09:57 AM
ripjaw memory overclocking kendallcschm Overclocking, Tweaking and Benchmarking 2 July 17, 2010 03:43 PM
G.Skill Releases the World's Fastest Memory, DDR3 2500 MHz Dual-Channel Memory Kit FiXT Press Releases & Tech News 10 April 14, 2010 07:49 AM
Hardware Upgrade's 11 kit DDR2 memory overclocking roundup Supergrover Reviews & Articles from the Web 2 January 3, 2007 08:27 PM
