Old March 18, 2008, 06:17 PM
DerekOldschool's Avatar
Default [email protected] on 780i overclock
So far, the results are very good
temps are 30-32C idle but peaked at 71C (core temps stayed about equal) early during prime testing. Generally, the temps stayed between high 50s and mid 60s depending on what fft length prime95 was using.
not a bad cpu for $75 and the ram was a great bargain as well!
Going to be trying 3.5Ghz testing tonight
i7-860 @ 4.0Ghz EVGA P55 FTW SLI (E657-A51 Bios) Thermalright ULTRA-120 Trueblack Rev.C G.Skill Ripjaws 4G DDR3-2000 Antec 850W TPQ EVGA 780 Ti Acer X263W 25.5" LCD Crucial C4 256G WD FAEX 1TB LG DVDRAM GH20NS10 Thermaltake Kandalf case Windows 7 Pro x64
E8400 @ 3.96Ghz (1.42v) EVGA 780i A1 (P08) ZalmanCNPS9700NT G.Skill 4G DDR2-1000 eVGA GTX280SC 1G Windows 7 Pro x64 1xSeagate Barracuda 7200.11 500G
Old March 18, 2008, 08:37 PM
Babrbarossa's Avatar
Hey! congrats on the great results- glad to see you've got your new gear
Old March 18, 2008, 09:11 PM
Thanks B - correct me if I'm wrong, but it looks like we have the same PSU and ram - so far both items are performing flawlessly, although the ram is still under testing......
I got the psu for my xmas upgrade in order to run sli on my old DFI Nforce 4 expert board - so far so good: a psu you can install and forget about it - lots of stable juice when you need it.
Old March 19, 2008, 05:04 AM
Mr. Cipher's Avatar
Wicked overclock. I'll add you to my stable rigs OC list!
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | Radeon HD 6870 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz |
BFG GTX 295 | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Old March 19, 2008, 05:16 AM
Yeah- I Like the PSU lots, but the RAM is just ok- not much for overclocking.
Old April 4, 2008, 09:20 AM
I also managed to get my E2160 running at 3.4GHz (9x378 on a DS3L). Tried 3.6GHz but I couldn't get the system to boot into Windows. Tried upping the voltage as far as 1.6V before calling it quits. Definitely happy with what the results though.
