Old February 11, 2012, 07:54 AM
r0k0's Avatar
Default BCLK Overclocking
I've been reading the Masterlair.com guide to OC the new i3/ i5/ i7 and they say to play with the BLCK but ppl have been saying on Sandy's not to touch BLCK is this true ?
cause raising the BLCK will raise the speed of everything same for the QPI which makes ( much faster less crowded highways )
Thanks
Main Rig
Intel Core i5 2500K - 5.0
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
AMD Radeon HD 6990 4GB 880 / 1300
Crosair 600T White / Enermax Revolution 920W
A-DATA 120GB SATA3 SSD / Seagates 1TB Spare SATA3
Canadian Eh ?
Old February 11, 2012, 11:19 AM
Thanks
All you need to do with SB processors is change the multiplier and perhaps some voltage.
Old February 11, 2012, 11:29 AM
r0k0's Avatar
yeah i'm already at 5.0Ghz but i would of lowered the multi and raise the BCLK but Guru3D been saying absolutly not to touch BCLK
Main Rig
Canadian Eh ?
Old February 11, 2012, 06:08 PM
103-104 will be the best you can get. 105+ is really rare. If you're already at 5,0 ghz, which is REALLY good, why bother?
Sandy Bridge-E limited BCLK? dma0991 Reviews & Articles from the Web 6 August 27, 2011 09:53 PM
What is default BCLK and Turbo Ratio for Intel Core i5 2500K? Tempstar CPU's and Motherboards 10 June 5, 2011 09:19 PM
~::NEED HELP::~ i5 750 - 160 bclk with power saving features + turbo boost enabled backpack Overclocking, Tweaking and Benchmarking 7 July 15, 2010 10:46 AM
what holds back high bclk? lowfat Overclocking, Tweaking and Benchmarking 15 September 30, 2009 08:06 AM
eVGA X58, poor BCLK overclocking. lowfat CPU's and Motherboards 9 April 16, 2009 11:08 AM
