-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   My First Overclock (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/5140-my-first-overclock.html)
Cardboard box with DSL March 18, 2008 11:46 AM
My First Overclock
1 Attachment(s)
I finally got over my fear of hurting my precious computer and decided gave over clocking a try.
I started in small increments and worked my way up to 3000mhz on stock voltages. Then I gathered my panties and started upping the vcore and managed to get to 3600mhz @ 1.5V (around 1.4Vish after vdroop), but it was really unstable, windows froze and getting it to POST was a 50/50 chance.
I then backed my FSB back to 377 (giving me 3400mhz with a max load temp of 52C) and am now testing away happily in windows. I had Prime 95 running for the better part of 2 hours, then started Orthos because it looks cooler:bleh:
I'm going to try to go higher after I get some ghetto cooling mods in there for my motherboard and RAM...
Specs:
e6600 @3.4 w/ Tuniq Tower
Asus P5B
7950Gt 256mb
3x1Gb Mushkin @5-5-5-12
500W Enermax Liberty
CM 690 Case
enaberif March 18, 2008 11:50 AM
I found with the e6600 you could usually get it to 3.4 stable without any issues and above that it would just crap out unless you had water cooling and feed it like 1.6v
Cardboard box with DSL March 18, 2008 11:51 AM
After having Orthos running for 15mins my computer started to make a higher pitched whistleing noise, which stopped after I shut Orthos off... Any idea on what could be doing that? Its kind of scary:ph34r:
Babrbarossa March 18, 2008 11:57 AM
It's the chipset voltage regualtors (should say something like r50 on them)- the 680i boards used to do it alot- nothing to be too alrmed about- just make sure there some good airflow across them- give them a touch too and see if they're scorching- I put little heatsinks on mine to cool them. On my old 680i the whining stopped after I put the heatsinks on
Cardboard box with DSL March 18, 2008 12:04 PM
Thanks Babrbarossa! Its certainly a relief to hear that its somewhat normal and fixable...
I just cranked the fans in my case and removed the side panel, which seems to have stopped the noise under load. Now my rig sounds like a leaf blower:thumb:
Cptn Vortex March 18, 2008 01:00 PM
Which mobo? 680i?
Cardboard box with DSL March 18, 2008 01:09 PM
Sorry I forgot to add my specs:doh:
My motherboard is a P5B, the rest of my specs are now in my first post.
3.0charlie March 18, 2008 01:55 PM
Great first oc! Have you raised the NB volts to stabilize the mild-high FSB? It may be why your oc is not stable at 3.6GHz.
60ninjas April 11, 2012 02:50 PM
hey guys i need some help with my overclocking is anyone on thats fairley advanced i have an expensive system that i dont want to hurt
stoanee April 11, 2012 02:57 PM
Waddaya have?
