Old March 14, 2008, 02:34 PM
Level up: 10% Level up: 10% Level up: 10%
Level: 11 - 305 points to level up
Default Overclocking/Benchmark Tools
I always find it hard to find hard to find all the best OC and BM tools in one place, as a noober it is even harder... SO...
Just thought I would start a thread prompting members to add links to their favorite benchmark and overclocking tools.
The key essentials that every overclocker and benchmarker should have.
Please add a brief description of what the tool does and any other pertinent info you feel should be passed on. As you add them I will try to move them systematically and to the front post.
CasheKicker
RIG #1 - AMD64 3500+ // Asus A8N-E // Radeon x1950xt // 2g Ram (4x512) // Basic Budget Case // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g
RIG #2 - Intel E8400 // TRU-X 120 w noctua NF-P12 // Gigabyte GA-X38-DQ6 // nVidea 8800GTS 512 OC // 4g Ram Crucial Ballistic PC8500 1066Mhz (4x1g) // Antec 900 Gamers Case // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Samsung 226BW & 17"KDS CRT/ Logitec G-15
Old March 14, 2008, 04:07 PM
MpG's Avatar
MpG MpG is offline
Level up: 62% Level up: 62% Level up: 62%
Level: 15 - 248 points to level up
Thought we had something like this already, but here's a few staples:
Stability Testing
Prime95
wPrime
Orthos
OCCT
Memtest86+
System Monitoring/Info
Speedfan
Coretemp
Everest
CPU-Z
Benchmarking
Futuremark - All PCMark/3DMark Programs
QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB
Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB
Old March 14, 2008, 04:09 PM
3.0charlie's Avatar
Test ram within Windows: Memtest MemTest: RAM reliability tester for Windows
Test stability: Prime 95 Prime95 - Overclock.net - Overclocking.net
CPU-Z: CPUID
Test Stability: OCCT Download - OCCT Website english
Test Stability: Super Pi mod XS 1.5 Super PI Mod
Test Stability: Orthos Download Stress Prime 2004 BETA
And you can add the Futuremark suite of 3Dmarks, Aquamark, etc.
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
Old March 14, 2008, 04:50 PM
Everest (benching system), SiSoft Sandra (benching system), Aquamark 3 (gpu), Fur Benchmark (gpu), Coretemp (temp monitoring), HD Tach (HD software)
Gigabyte P35-DS3R | E2180 @ 3.4ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 510mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900.
Intel E1xxx & E2xxx OC Thread
Old March 14, 2008, 04:53 PM
Level up: 13% Level up: 13% Level up: 13%
Level: 17 - 692 points to level up
I get the latest and greatest Prime95 from here: PrimeNet - mersenneforum.org
Xeon Quad X3350 | 3.40GHz (Damn X38 chipset)
ASUS Maximus Formula | BIOS RF0410
2GB Corsair Dominator | 850MHz
4-4-4-12-2T
2GB OCZ Platinum Rev2 | 850MHz 4-4-4-12-2T
HIS ICEQ4 Turbo HD4850 @ 700/1200
X-Fi XtremeMusic
Antec TruePower Quattro 850W
Antec 900
[ HEATWARE ]
Old March 20, 2008, 01:03 PM
Level up: 83% Level up: 83% Level up: 83%
Level: 12 - 70 points to level up
ok being a neeeb to overclocking and such how can I bench mark my comp I just want to see if everything is running up to par when stock?
Old March 20, 2008, 01:35 PM
Level up: 8% Level up: 8% Level up: 8%
Level: 14 - 540 points to level up
I'd suggest sisandra lite, you can do all the benchmarks with that to see exactly how well your system is performing in all areas, ie. cpu, ram, hard drive... then you can save the results as a snapshot of the "Before", then OC your system as you like and benchmark them all again to see just how much improvement you get. I really dont think the 3d benchmarks are good for this as they tend to lean on the 3d aspect of your system. for example, myself, i get about 12000 3d marks (with '06) with my computer at stock, while bringing my cpu up to 4.0ghz (from 2.4) only brings my score to a little over 13000 3d marks, while overclocking my gpu brings my score to a little over 15000. Also, sisandra will show you how your computer rates against other similar builds and in which areas, as well as suggesting solutions to problems it might see.
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
wPrime Benchmark v1.58 Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 5 February 5, 2008 12:55 PM
3DMark05 Benchmark Prof. Dr. Silver Overclocking, Tweaking and Benchmarking 4 November 15, 2007 10:43 PM
Not Quite Modding - Tools Related Drew Cases 2 September 30, 2007 09:27 AM
My Favourite Anti Malware Tools clickright General 7 May 13, 2007 06:59 PM
