Just a lil update and then you can get back to shouting at each other
Just talking here friend, not shouting
We all have our options and are entitled to them, mine is no more important then the next .
Whether you see wisdom in mine, your own or some one different is of course up to you seeing as it is not for me to tell you what you should or shouldn't think, I can only show you doors, you must pick the one you wish to go threw.
Wisdom & Intelligence is the ability to use knowledge.
Knowledge is the ability to see that which is obvious for with out it nothing ever is.
And there is no knowledge that is not power.
And how you use it Whether for good or evil defines you,and theirs is a little bit of everything in all of us.
And closed mindedness and intolerance to differences of options walks hand in hand with pride and ignorance.
And iv bin doing this for 30 year since per 1mhz cpus.
