Old January 9, 2012, 06:38 AM
gingerbee's Avatar
Default ok just some folks thought on the max vcore stuff i5/i7
Well hi to all you overclockers i was just fine tuning some of my overclocks and i have some new kit i5 2500k and a maximus extreme-z board which i love.
Now after playing a bit i have noticed that this great little chip i have will boot into windows @5.0ghz with a 50x muliti so my question is what do folks think about the buzz in the web that max vcore for sandybridge is 1.52 ???.
I myself think this is crazy high but after going upwards of 1.4 i haven't noticed a huge increase in temps at all and that only on air. Now i have been overclocking for many years now every since the pentium4/athlon days so i do know what i am doing cause i have a bad habit of buying every socket out there lmao.
So i guess my other question is also why was it not a good idea going above 1.45 on 45nm but it's ok on 32nm and yes i understand Wikipedia, the free encyclopediaElectromigration
Old January 9, 2012, 09:28 AM
martin_metal_88's Avatar
Personally I always stopped myself at 1.4 since the first day of 775. CPU use the same power ( 95W ) and are printed smaller ( 22nm ) so I don't see why all of a sudden they would be able to take up to 1.5. What would make sense ( and what I have read most of time ) is that 1.4 is the max and 1.52 is the absolute max ( suicide run ).
Old January 9, 2012, 10:40 AM
gingerbee's Avatar
ya me too i have always stopped at 1.4vcore i am really just wondering cause i am going to push this little i5 to the ragged edge and see what she can do
Old January 9, 2012, 11:32 AM
Dead Things's Avatar
Meh - almost all my chips have seen 1.69v at one time or another. So far, they've all lived to tell the tale.
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Follow my benching, folding, mining and miscellaneous shenanigans @dt_oc
Old January 9, 2012, 12:23 PM
i have ran chips at 1.45v for a long time with no ill effects.
Old January 9, 2012, 12:56 PM
I went 1.5V with a Phenom 9950 - the motherboard failed first though (Asus M3A78-T with 4-phase regulators). Half-failed board is currently running a dual core in my bro's computer as I didn't want to take all the steps to RMA it.
Old January 17, 2012, 05:42 AM
+1
agreed, though i went looking for the wight paper for the i5 2500k and didn't find it, but your statement sounds about right
though i did do some research on the topic and best i can tell its just like the older cpus from Intel meaning 1.4v
Vcore greyed out ... DRZDuke CPU's and Motherboards 1 July 5, 2010 12:07 PM
Q6600 Freakishly low vcore Digital_fx3 Overclocking, Tweaking and Benchmarking 16 October 7, 2009 04:46 PM
Phenom II X2 550 -X4 Vcore max mattlef CPU's and Motherboards 3 August 29, 2009 05:20 PM
vcore fluctuations and oc magictorch Overclocking, Tweaking and Benchmarking 11 July 5, 2007 01:40 PM
I'm now confused Vcore real or not? Delavan Overclocking, Tweaking and Benchmarking 4 June 12, 2007 04:56 AM
